suprafan72 Posted June 25, 2007 Share Posted June 25, 2007 I have took my RTLC off.. and just wondered what the other alternatives are to better traction? R888's...? Ive got my suspension sorted.. but wont to avoid the route of electronic aid's... Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 25, 2007 Share Posted June 25, 2007 The right hand pedal will serve this function beautifully, when used correctly Link to comment Share on other sites More sharing options...
RedM Posted June 25, 2007 Share Posted June 25, 2007 Although I don't have any idea about this I have wondered this myself. Is it a given that upping the power means having to go with bigger, wider wheels/tyres? Eyefi has a very quick Supra that he's still running on stock 17's. Although I believe he has really fine-tuned his RLTC to compensate. Anyway, curious and subscribed. Link to comment Share on other sites More sharing options...
garetheves Posted June 25, 2007 Share Posted June 25, 2007 First thing i do when i get in mine is turn the Standard TC off and i never have any traction issues. Admitedly mine isnt running quite the same power as yours but its still a single. Just feather the throttle more instead of trying to plant your foot through the floor. Link to comment Share on other sites More sharing options...
Sheefa Posted June 25, 2007 Share Posted June 25, 2007 I'm BPU and now frequentl switch all RLTC and TC aids off!!! Not a good thing I know, but it's more grief than anything at the mo having it on! Would a TRD Diff help gain traction? Link to comment Share on other sites More sharing options...
suprafan72 Posted June 25, 2007 Author Share Posted June 25, 2007 Thanks guys... Yes the pedal is i guess the only answer! Link to comment Share on other sites More sharing options...
Ryan.G Posted June 25, 2007 Share Posted June 25, 2007 Use lower boost in the gears where the traction becomes a problem and then more in the higher gears where traction is permitting this is a feature of the avcr boost controller i love. Ryan Link to comment Share on other sites More sharing options...
Branners Posted June 25, 2007 Share Posted June 25, 2007 The right hand pedal will serve this function beautifully, when used correctly Its true that correct use of the right pedal will be enough, but I would suggest that very few people can actually use it correctly in the right conditions. I know that I would never be without RLTC now. You think you know the car well and just when you least expect it (wet road, right hand bend off a roundabout) it bites, throws you in to the armco and the car is dead. First ever mkiv I saw killed went that way, the owner fitted RLTC on its replacement. I would suggest you get the RLTC put back in and get it set up by somebody who knows it very well. The difference in config files can make a massive difference to those who are not racing car drivers JB Link to comment Share on other sites More sharing options...
suprafan72 Posted June 25, 2007 Author Share Posted June 25, 2007 To be honest im very careful on boost, and allways step it in 2nd and 3rd.. and never floor it totally and it has to be in the bone dry... Link to comment Share on other sites More sharing options...
Gamer Posted June 25, 2007 Share Posted June 25, 2007 Get RTLC back into that car. I would never dream of having my car without it. Why did you remove it ? Link to comment Share on other sites More sharing options...
Muffleman Posted June 25, 2007 Share Posted June 25, 2007 R888s will help, I like my TRD diff and good geometry most certainly helps. My car has never really caught me out, and I wouldn't put rltc or anything else on. It has excellent mechanical grip and the back comes out very progressively in the dry, can be held on the throttle without too much drama. Just take your time getting used to it, find your limits and drive within them. Oh, and drive the missus car in the wet Link to comment Share on other sites More sharing options...
Guest Nicholas Posted June 25, 2007 Share Posted June 25, 2007 single's in the wet can be great fun, I had a brilliant time on the way to the pod on sunday just make sure you have a good suspension setup with good tyres. Link to comment Share on other sites More sharing options...
Muffleman Posted June 25, 2007 Share Posted June 25, 2007 I actually found my bone stock TT auto with stock wheels, suspension etc more of a handful in the wet than my single Traction in that was hopeless !!! Link to comment Share on other sites More sharing options...
michel lane Posted June 25, 2007 Share Posted June 25, 2007 get your car suspension setup correctly with all the alignments sorted by someone who knows what they are doing e.g C.WILSON . I dont have issues with traction , nor do i use RLTC but i do use R888. look at the setup before resorting to electronic gismo's. Else take a driving course :-) Link to comment Share on other sites More sharing options...
Branners Posted June 25, 2007 Share Posted June 25, 2007 surely R888 would be suicide in the wet, they look pretty close to a cut slick.... JB Link to comment Share on other sites More sharing options...
Wez Posted June 25, 2007 Share Posted June 25, 2007 I dont use any form of TC, I found rear traction degraded when going from 255 to 275 rears, I now run stock 17" sizes on R888s. 1st, 2nd and 3rd are only a prob when the tires are cold, once they have warmed up the grip is great, my suspension was setup by CW using JIC FLT A2s. Link to comment Share on other sites More sharing options...
Wez Posted June 25, 2007 Share Posted June 25, 2007 surely R888 would be suicide in the wet, they look pretty close to a cut slick.... JB I deff would not want to hit a puddle in them Link to comment Share on other sites More sharing options...
Pig Posted June 25, 2007 Share Posted June 25, 2007 I run stock 17's - traction is impossible in 1st and 2nd @ WOT RLTC is going back on this week, was GREAT fun without it. At least it has an off switch Tyre and suspension choice next Link to comment Share on other sites More sharing options...
suprafan72 Posted June 25, 2007 Author Share Posted June 25, 2007 Mr wilson has kindly done the honours and it made the world of difference.. i will look at changing the rear tyres.... with the new Geo setup i dont go sideways thats for sure.. allways good. Link to comment Share on other sites More sharing options...
mr keef Posted June 25, 2007 Share Posted June 25, 2007 I thought you'd just got the rltc fitted not so long ago mate?why the change of heart? Link to comment Share on other sites More sharing options...
suprafan72 Posted June 26, 2007 Author Share Posted June 26, 2007 I thought you'd just got the rltc fitted not so long ago mate?why the change of heart? it didnt work mate, and it couldnt be made to work... Link to comment Share on other sites More sharing options...
Jake Posted June 26, 2007 Share Posted June 26, 2007 I can't drive my single without RLTC. I've tried to, but frankly it's facking dangerous without it. I've been meaning to have a word with Phil about my RLTC actually because it seems to only just cope at the moment. I'm sure it should be better than it is. Link to comment Share on other sites More sharing options...
mr keef Posted June 26, 2007 Share Posted June 26, 2007 it didnt work mate, and it couldnt be made to work... lol strange:blink: Link to comment Share on other sites More sharing options...
Homer Posted June 26, 2007 Share Posted June 26, 2007 Had an interesting chat with suprafan72 on PM... He's still on the same Japenese tyre's it came over with so have suggested these are changed for some new all weather ones as a start. His suspension has been sorted by CW, so that should be in order. Lets see how it progresses after the tyre change FWIW: I'm finding it okay without traction control on my car so far. It does spin up very easily in 1st and 2nd in the dry, but you just need to use the right foot carefully. In the wet it's much more of a handful, but I just limit WOT usage in the lower gears when it's damp or wet. I did get a 110mph drift on the M1 back from Pod yesterday, but will take it as a learning experience to not use 100% throttle when it's damp. RLTC will no doubt allow me to use near 100% throttle everywhere, but I'd rather rely on my own inputs than a box of tricks to do everything for me... at least until I know exactly how the car handles on the single. Link to comment Share on other sites More sharing options...
neil tt Posted June 26, 2007 Share Posted June 26, 2007 So who would be the best person to fit RLTC:) Link to comment Share on other sites More sharing options...
