Delfin Posted June 24, 2007 Share Posted June 24, 2007 As I'm getting my oil problem looked after I thought I might aswell get my speedo fixed . Now, as stated in my other thread, the speedo just went dead after I entered the highway, no signs of it happening before. Just like that. Does this happen to have anything to do with the oil leak or am I just double unlucky? If so, is there any easy way for me to check the wireing, connectors or other things that might lead to this? I am taking the car to Toyota as soon as I can, but would be good to have a general idea of things first, as I don't want them to fook around too much with my car. Cheers! Link to comment Share on other sites More sharing options...
SteveR Posted June 25, 2007 Share Posted June 25, 2007 I would open the dash up and see what's come loose. Have you got a delimiter fitted? Chances are a connection has failed - should be pretty obvious, if you're lucky and the converter is behhind the dash. Check out my how to fit a converter thread for a few pics behind the dash - might help. Link to comment Share on other sites More sharing options...
Steviekid Posted June 25, 2007 Share Posted June 25, 2007 I've got a thor converter and my speedo stopped working all of a sudden. All I had to do was disconnect the battery for a while and it was fine (the unit apparantly "resets" itself). Link to comment Share on other sites More sharing options...
Delfin Posted June 25, 2007 Author Share Posted June 25, 2007 Great, thanks for the replies guys, will check it out . Paul installed a delimiter for me when I bought the car, don't know which kind thou, will PM and ask. You're invaluable! Link to comment Share on other sites More sharing options...
