TLicense Posted October 9, 2004 Share Posted October 9, 2004 OK chaps, I've downloaded the epc programme and that unzipped and worked fine. I then downloaded both the 500 odd meg files labelled Jap97a1.iso.gz and jap97a2.iso.gz I then copied the first file to disc and labelled the disc 19970213J1 I then went to the epc programme and went to the disc set-up, ticked the european set up. Set the input file to d: and then changed the A1 to hard disc. I then hit exec but get a load of error messages. Am I doing something wrong? Cheers Tony Quote Link to comment Share on other sites More sharing options...
matt Posted October 9, 2004 Share Posted October 9, 2004 iso is a cd image. Burn 2 cd's and label them as above and you'll be good to go Quote Link to comment Share on other sites More sharing options...
matt Posted October 9, 2004 Share Posted October 9, 2004 oops misread it Quote Link to comment Share on other sites More sharing options...
SimonB Posted October 9, 2004 Share Posted October 9, 2004 Originally posted by TLicense I then hit exec but get a load of error messages. Am I doing something wrong? Cheers Tony Was it something about not enough disk space by any chance? There's a bug in it - it doesn't like modern big hard disks and gets confused by the amount of free space available. You have to copy a big file loads of times so there's not much space left and then install it. Quote Link to comment Share on other sites More sharing options...
TLicense Posted October 9, 2004 Author Share Posted October 9, 2004 OK I've just downloaded the file from arnout's site which was 26 meg instead. Again I named the disc 1997... whatever it was. Do I need to try and extract the jap97a1.iso.gz or something or literally just copy it do disc and run it? The error is something like gcsetup,cmd,get_input_dat/setclentinfo, (13)(0)(0) I'm going to try and download a load of .rar files that I've found. This is starting to get annoying. Cheers guys Tony Quote Link to comment Share on other sites More sharing options...
michael Posted October 9, 2004 Share Posted October 9, 2004 If you are running 19970213J1 you don't want it in the Euro setup box, try the other options (don't have the EPC on this PC to check but isn't there an Asia section?) If this doesn't help try changing the drive letter selector to the hard disk designation rather than CD. Quote Link to comment Share on other sites More sharing options...
matt Posted October 9, 2004 Share Posted October 9, 2004 The .gz file needs to be extracted. This will give the .iso file You then create a cd from the iso image..... Quote Link to comment Share on other sites More sharing options...
matt Posted October 9, 2004 Share Posted October 9, 2004 I used japanese area in the cd setup Quote Link to comment Share on other sites More sharing options...
TLicense Posted October 9, 2004 Author Share Posted October 9, 2004 I've just tried all of the area's including the frame no. cd with both d: and c: drives. No luck. If I set c: it can't find the disc. Quote Link to comment Share on other sites More sharing options...
TLicense Posted October 9, 2004 Author Share Posted October 9, 2004 Ahh cheers matt, I'll give it a go. Quote Link to comment Share on other sites More sharing options...
