Dave Posted June 22, 2007 Share Posted June 22, 2007 my sons supras front pulley has come loose and the belt has come off any advice on what we should do .does the rad need to come out to re torque it and are there any special tools needed . btw the pulley hasnt broken its still intact thanks in advance for any help---dave Quote Link to comment Share on other sites More sharing options...
Jake Posted June 22, 2007 Share Posted June 22, 2007 the pulley hasnt broken its still intact I bet it's not. If you do a search for threads with Crank Pulley in the Titles, and Show Results as Threads you will find everything you need to know. Good luck Dave. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted June 22, 2007 Share Posted June 22, 2007 Even though it may not look broken it will be, the 2 halves will have split Im afraid its time for a new pulley. IIRC Rad needs to be removed, you will also need a special took to retorque the new one down. Quote Link to comment Share on other sites More sharing options...
Dave Posted June 22, 2007 Author Share Posted June 22, 2007 where does it break it looks like the pulley nut has just come loose .and the pulley has sliped forward . are the two pulleys on the crank joined then? timing belt pulley and the front one ?? where can i get a new pulley MR T or does someone on here do them. Quote Link to comment Share on other sites More sharing options...
Jake Posted June 22, 2007 Share Posted June 22, 2007 The pulley has a bolt rather than a nut, Dave. It's supposed to be a single piece pulley but sometimes the outer ring separates from the inner part. Can you take a photo of it for us to see better? Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted June 22, 2007 Share Posted June 22, 2007 £220 (ish) plus VAT from toyota or circa £140 from 'Nic the import pimp' if you can wait 5/6 weeks Quote Link to comment Share on other sites More sharing options...
uk-rich Posted June 22, 2007 Share Posted June 22, 2007 you can leave the rad on Quote Link to comment Share on other sites More sharing options...
Class One Posted June 22, 2007 Share Posted June 22, 2007 And as you've an auto you should be able to get the nut off using the starter trick and do it up by jamming up the viscous coupling with a suitable wedge shaped tool at the back of the engine. Quote Link to comment Share on other sites More sharing options...
Dave Posted June 22, 2007 Author Share Posted June 22, 2007 And as you've an auto you should be able to get the nut off using the starter trick and do it up by jamming up the viscous coupling with a suitable wedge shaped tool at the back of the engine. can you explain that please class one m8 thanks my mate works a A.T.S and he said if he can get the airgun on it you wont need a special tool to hold the crank is this right ? just pm.d a fellow called hodge who can supply them for £30 Quote Link to comment Share on other sites More sharing options...
Jake Posted June 22, 2007 Share Posted June 22, 2007 I think Doug means Torque Converter rather than Viscous Coupling. Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted June 22, 2007 Share Posted June 22, 2007 just pm.d a fellow called hodge who can supply them for £30 Yeh I wouldn't bother with that if I were you Quote Link to comment Share on other sites More sharing options...
Class One Posted June 22, 2007 Share Posted June 22, 2007 That'll be the one Jake. To get the bolt off the crank pully damper you'll find that it is done up FT. As yours is an auto you'll need to jam on a socket and wrench and wedge that into something solid like the ground so it wont moveit and have someone else turn the car over for about 0.2 of a second. That should loosen it up enough to get off. To do the new one up tight enough, as its an auto you can't lock up the engine via the gearbox. Therefore at the back you'll find the TC, using a wedged shaped long enough tool you should be able to jam that up whilst doing up the crank damper. This will need to be done up very FT. It's a bit of a pain, but if you know, or your mate knows what he's doing the he should be able to manage it. Don't buy a cheap damper. Only buy a MR T one. Quote Link to comment Share on other sites More sharing options...
RedM Posted June 22, 2007 Share Posted June 22, 2007 I've just bought one of these and planned to do it myself. I think I might just take it to one of those men in overalls. They need to do my rear suspension arms too. Quote Link to comment Share on other sites More sharing options...
Shane Posted June 23, 2007 Share Posted June 23, 2007 That'll be the one Jake. To get the bolt off the crank pully damper you'll find that it is done up FT. As yours is an auto you'll need to jam on a socket and wrench and wedge that into something solid like the ground so it wont moveit and have someone else turn the car over for about 0.2 of a second. That should loosen it up enough to get off. To do the new one up tight enough, as its an auto you can't lock up the engine via the gearbox. Therefore at the back you'll find the TC, using a wedged shaped long enough tool you should be able to jam that up whilst doing up the crank damper. This will need to be done up very FT. It's a bit of a pain, but if you know, or your mate knows what he's doing the he should be able to manage it. Don't buy a cheap damper. Only buy a MR T one. Its got to be worth a try using this method, loads of people on here have done it this way and it's been fine. But in my case it wouldnt budge using the starter. I then tried several air guns at tyre places and still wouldn't budge, I ended making a tool. Chris sz also had simular problems I recall. Got to be worth a try first, but be prepared to find, borrow, make or steal a tool. Sims toyota in Northampton dont even have a tool! They rely soley on the method Doug describes, but even they end up taking the car to a lexus dealer who has the correct tool sometimes. There is a guy on here who will lend you a tool, he does it by post. If you get stuck let me know and I will find his details. Quote Link to comment Share on other sites More sharing options...
markssupra Posted June 23, 2007 Share Posted June 23, 2007 Dave, pm me if you need to borrow tool to lock crank pulley. It just bolts on the front and locks against chassis rail in engine bay. Click on the crank pulley link in my sig and you will find a picture of it. Quote Link to comment Share on other sites More sharing options...
Shane Posted June 23, 2007 Share Posted June 23, 2007 Dave, pm me if you need to borrow tool to lock crank pulley. It just bolts on the front and locks against chassis rail in engine bay. Click on the crank pulley link in my sig and you will find a picture of it. That's the guy I am talking about! Quote Link to comment Share on other sites More sharing options...
Dave Posted June 23, 2007 Author Share Posted June 23, 2007 Dave, pm me if you need to borrow tool to lock crank pulley. It just bolts on the front and locks against chassis rail in engine bay. Click on the crank pulley link in my sig and you will find a picture of it. thats a very good guide mate can you say where the best place to get a new pulley from the one on has split Quote Link to comment Share on other sites More sharing options...
Jake Posted June 23, 2007 Share Posted June 23, 2007 Has yours split then Dave? (I may have missed an update) Quote Link to comment Share on other sites More sharing options...
molak Posted June 24, 2007 Share Posted June 24, 2007 my bottom pulley has done the same, it splits from the rubber vibration damper in the middle. i got new pulley from ebay for £30 light weight one! Quote Link to comment Share on other sites More sharing options...
markssupra Posted June 24, 2007 Share Posted June 24, 2007 Molak, not sure those lightweight ones are any good though. The toyota one is designed to dampen out the crankshaft vibrations. Gets ready to be Quote Link to comment Share on other sites More sharing options...
garethr Posted June 24, 2007 Share Posted June 24, 2007 Sims Toyota in Northampton don't even have a tool! ......they end up taking the car to a Lexus dealer who has the correct tool......That's unbelievable at the prices main dealers charge. The Toyota SST costs about 110 quid IIRC. They must figure they don't see enough JZs. Cheapskates! Quote Link to comment Share on other sites More sharing options...
Rob Posted June 24, 2007 Share Posted June 24, 2007 Take Markssupras tool into the dealership with you then ask "Where's your tool?" (Service Manager) "What f@*()ing tool?" I'll leave you to imagine the rest... Quote Link to comment Share on other sites More sharing options...
