CANDYMAN666 Posted June 21, 2007 Share Posted June 21, 2007 Hi there all you fellow Supra dudes has anyone bought the "Real Carbon Fiber" dash kit off E Bay from woodashtrims ? Is it any good....????? Or should I stay well clear????: Quote Link to comment Share on other sites More sharing options...
Guest four o two Posted June 21, 2007 Share Posted June 21, 2007 Haven't used that particular kit from eBay, but I did have a CF dash kit installed but got tired of it. I ended up taking it off and re-painting my dash panels flat black. I did leave the CF on the window switches and passenger side air vents. Sorry I'm not much help. Quote Link to comment Share on other sites More sharing options...
CANDYMAN666 Posted June 21, 2007 Author Share Posted June 21, 2007 Thanks Mate what was it that made you get tired of it...?:) Quote Link to comment Share on other sites More sharing options...
squiffy Posted June 21, 2007 Share Posted June 21, 2007 i got the one from kynu and it was fine, great look. i know its pictured as a left hooker but its not. (best to email just in case!) http://cgi.ebay.co.uk/TOYOTA-SUPRA-93-94-98-REAL-CARBON-FIBER-DASH-KIT-TRIM_W0QQitemZ120134672334QQihZ002QQcategoryZ10428QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
CANDYMAN666 Posted June 21, 2007 Author Share Posted June 21, 2007 Thanks will look at site now.....cheers:) Quote Link to comment Share on other sites More sharing options...
wallace9 Posted June 22, 2007 Share Posted June 22, 2007 I had one on my car when I bought it. Lokked ok but in the middle of spraying it just now. Looks alot better imo Quote Link to comment Share on other sites More sharing options...
rick001 Posted June 22, 2007 Share Posted June 22, 2007 I have 1 of these kits mate and i like it - see my garage rick Quote Link to comment Share on other sites More sharing options...
CANDYMAN666 Posted June 22, 2007 Author Share Posted June 22, 2007 Cheers Rick....Looks Cool in Pic.....was it easy to fit???:) Quote Link to comment Share on other sites More sharing options...
uzthedentist Posted June 23, 2007 Share Posted June 23, 2007 it looks pretty good, but I had to cut mine with a hot knife to get it to fit Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 23, 2007 Share Posted June 23, 2007 Nic does the water transfer process, covering the entire dash with carbon, It looks real and has zero gaps, its a bit pricier, but by far the best you can get. Quote Link to comment Share on other sites More sharing options...
fishman Posted June 23, 2007 Share Posted June 23, 2007 Nic does the water transfer process, covering the entire dash with carbon, It looks real and has zero gaps, its a bit pricier, but by far the best you can get. does he only do supras, or can he do anything else....? and do you have any idea on the cost? Thanks Quote Link to comment Share on other sites More sharing options...
kslb Posted June 23, 2007 Share Posted June 23, 2007 Lovin the carbon dash look, I would always leave standard if it was tidy but if not would go Carbon without a doubt. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 25, 2007 Share Posted June 25, 2007 Not sure mate, speak to nic Quote Link to comment Share on other sites More sharing options...
Nic Posted June 25, 2007 Share Posted June 25, 2007 does he only do supras, or can he do anything else....? and do you have any idea on the cost? Thanks I can do any plastic parts, but would need the parts to coat. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 25, 2007 Share Posted June 25, 2007 Nic does the water transfer process, covering the entire dash with carbon, It looks real and has zero gaps, its a bit pricier, but by far the best you can get. Dan Quote Link to comment Share on other sites More sharing options...
gaz1 Posted June 25, 2007 Share Posted June 25, 2007 i have one of nics and it looks great;) Quote Link to comment Share on other sites More sharing options...
rick001 Posted June 25, 2007 Share Posted June 25, 2007 Cheers Rick....Looks Cool in Pic.....was it easy to fit???:) Yeah its dead easy, follow instruction with adhesive primer cleaning cloths and use a hair dryer and there you have it. I had to trim very slightly the arm rest area but if your careful its fine Quote Link to comment Share on other sites More sharing options...
Sheefa Posted June 25, 2007 Share Posted June 25, 2007 Yep, happy with mine here too. Although given the chance again, I would go with one from Nic as it simply outclasses the stick on one. Quote Link to comment Share on other sites More sharing options...
RiceRocketUk Posted June 26, 2007 Share Posted June 26, 2007 whatn happens around the gearshift on these kits as manuals and autos are different, from the look of it id doesnt cover all the part around the gearshift can someone please advise Quote Link to comment Share on other sites More sharing options...
