Carbon Fibre Dash Kits
CANDYMAN666
Guest four o two
Haven't used that particular kit from eBay, but I did have a CF dash kit installed but got tired of it. I ended up taking it off and re-painting my dash panels flat black. I did leave the CF on the window switches and passenger side air vents.
Sorry I'm not much help.
Nic does the water transfer process, covering the entire dash with carbon, It looks real and has zero gaps, its a bit pricier, but by far the best you can get.
does he only do supras, or can he do anything else....? and do you have any idea on the cost?
Thanks
Cheers Rick....Looks Cool in Pic.....was it easy to fit???:):)
Yeah its dead easy, follow instruction with adhesive primer cleaning cloths and use a hair dryer and there you have it. I had to trim very slightly the arm rest area but if your careful its fine :D
