imi Posted June 21, 2007 Share Posted June 21, 2007 As some of you may know that on the way to Daytona one of the water pipes burst and thx to Matt and Henk we managed to replace it. Thread post here http://www.mkivsupra.net/vbb/showpost.php?p=1460466&postcount=63 Today, I floored the car after a few days with the new clutch to see how much better it is and yes, you guessed it, the same flippin water pipe burst again. I have highlighted the area where the two pipes are located (under the intercooler pipe), seems like the jubilee clip of the lower pipe is cutting into the pipe above... Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted June 21, 2007 Share Posted June 21, 2007 fix...put some tape over over the clip after it has been tightened so there is no sharp edges. Quote Link to comment Share on other sites More sharing options...
imi Posted June 21, 2007 Author Share Posted June 21, 2007 fix...put some tape over over the clip after it has been tightened so there is no sharp edges. Good shout......damn....we had some tape at Daytona too.. Quote Link to comment Share on other sites More sharing options...
imi Posted June 21, 2007 Author Share Posted June 21, 2007 just had a look at the pipe, its ruptured pretty badly, dont think its due to the jubilee clip, think the pressure was too much for the pipe to handle.... will have a better look in the morning in the sunlight...(assuming its a clear day) Quote Link to comment Share on other sites More sharing options...
Homer Posted June 21, 2007 Share Posted June 21, 2007 WSB probably has it right here, you don't want to be using those crappy silicon hoses on those water pipes, they offer no grip. Get some new stock ones back on and go from there. Also, why the silicon hoses on the IC pipework? Odd! Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 22, 2007 Share Posted June 22, 2007 fix...put some tape over over the clip after it has been tightened so there is no sharp edges. Buy better quality hose clips with rolled edges, my hose's have been on for a number of years with no issues, Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 22, 2007 Share Posted June 22, 2007 Also, why the silicon hoses on the IC pipework? Odd! Why not ? Quote Link to comment Share on other sites More sharing options...
AndyT Posted June 22, 2007 Share Posted June 22, 2007 Rolled edge quality clips are the way ahead. Don't know about pro's cons of the different hoses though. And Imi you need the better horns to finish it off bud. Imo of course. On a side note. Homers note on using stock items is not the first time I've seen it mentioned that stock beats aftermarket. Our esteemed Mr Wilson advised that the stock belts were better than aftermarket in most situations. Even over PE items. This car was quality built and Toyota used good quality parts to make it reliable. So, just in case you disregard stock when it's mentioned, as I tend to do. Don't. Stock is sometimes better. Quote Link to comment Share on other sites More sharing options...
imi Posted June 22, 2007 Author Share Posted June 22, 2007 Does anyone know the part number of those two pipes, I will order them from Toyota today and fit them. Quote Link to comment Share on other sites More sharing options...
Henk Posted June 22, 2007 Share Posted June 22, 2007 Imi m8, I was wondering whether the replacement pipe you got from Daytona was of a high enough rating to take the way you drive your car... Let's be honest you don't hang about much... Also rather than get the original Toyota Part is there such a thing as an uprated version? Sorry if this is a stupid suggestion, I am after all a technical numptie Quote Link to comment Share on other sites More sharing options...
Ric Posted June 22, 2007 Share Posted June 22, 2007 goto toyota as sombody has mentioned or get some fuel/water hose from your local motor spares, its not a very sharp bend so stright pipe should bend around without kinks Quote Link to comment Share on other sites More sharing options...
imi Posted June 22, 2007 Author Share Posted June 22, 2007 goto toyota as sombody has mentioned or get some fuel/water hose from your local motor spares, its not a very sharp bend so stright pipe should bend around without kinks I cut the pipe ans refit it; was good enough to get me to my parents, will get some proper pipe as I dont think this will last the next 160 lepton run Quote Link to comment Share on other sites More sharing options...
Ric Posted June 22, 2007 Share Posted June 22, 2007 I cut the pipe ans refit it; was good enough to get me to my parents, will get some proper pipe as I don't think this will last the next 160 lepton run yes but looking at the picture your using small diameter silicon hose for the water pipes, which IMO is too thin/soft hence why its splitting under pressure (which is im assuming is happening) which is why i said fuel / proper rubber water hose Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 22, 2007 Share Posted June 22, 2007 I recently replaced these two pipes on mine, I spotted one of the pipes was degrading and would'nt last much longer. So of I went and bought some generic hose of the same diameter. However, they didn't fit. The interior diamter is way to small on normal pipe. Get to toyota and buy stock ones, they are only cheap, I'll see if I can find the part numbers for you. Quote Link to comment Share on other sites More sharing options...
imi Posted June 22, 2007 Author Share Posted June 22, 2007 Get to toyota and buy stock ones, they are only cheap, I'll see if I can find the part numbers for you. Many thx bud, this is what I intend to do tomorrow, can you please PM me the part numbers when you get the chance. imi Quote Link to comment Share on other sites More sharing options...
Homer Posted June 22, 2007 Share Posted June 22, 2007 The part numbers are the same for each hose so I guess they need to be trimmed to suit: 16284-46020 Quote Link to comment Share on other sites More sharing options...
imi Posted June 22, 2007 Author Share Posted June 22, 2007 Thx bud, exactly what I was looking for. Quote Link to comment Share on other sites More sharing options...
