Clutch ?!?!?!?
toyo rob
right, background first,
due to some very unfortunate circumstances and a run of bad luck i have recently changed the car so naturally thought, if i've got to do it, i might as well do it properly!!. so did a full de cat, upgraded my 10yr old SMIC for a CW one, upgraded the fuel pump and put on a DSBC spec R.:(
Problem:
now when in any gear higher than 2, when the boost goes above about 0.6 bar the revs go up, the boost kicks in BUT the car takes time to catch up. NOw is that just a worn out clutch which needs changing or is that running too much torque/bhp for my current clutch??:twak:
Now the REAL questions:
DO i go for an uprated clutch or a Twin Plate??
And if TWin which is good, the RPS looks a bit tasty!!!
Cheers
Rob S:music::thumbs:
