Guest PyAri Posted June 21, 2007 Share Posted June 21, 2007 Hi, This is my first post and I am hoping that one of you can help me. I tried searching through the topics, but I didn't find anything similar to my issue. The alternator on my car went bad a few weeks ago. I took it to be replaced 2 days ago and when I came back home I realized that the trac light, not the TRAC OFF light, stays on. I've never seen this light before. What does it mean? How do I turn it off? I know the guy couldn't get the car to idle so he turned that up, but as far as I know that's the only thing he did other than replacing the alternator. What is causing this light to be on? Pic attached below: http://pyari.zoomshare.com/files/IMG00028.JPG Thank you for any help in advance. Link to comment Share on other sites More sharing options...
spidermonkey Posted June 21, 2007 Share Posted June 21, 2007 maybe a blown fuse for the traction control?? Link to comment Share on other sites More sharing options...
part_timer Posted June 21, 2007 Share Posted June 21, 2007 The fuse for the TRAC is the same on for the power steering and the antenna. If these also dont work, you've blown the fuse; 2 minute job to replace. (Mines calls it "slip control" though so i might be wrong) Link to comment Share on other sites More sharing options...
csa Posted June 21, 2007 Share Posted June 21, 2007 hmm...my TRC light is also on, ant the antenna doesn't work, but the powersteering works just fine...is that also a fuse problem? Link to comment Share on other sites More sharing options...
supradibbs Posted June 21, 2007 Share Posted June 21, 2007 are you sure he just adjusted the cable if he has ove the sub throttle sensor at all this will cause this if i remember correctly if not try reseting the ecu Link to comment Share on other sites More sharing options...
Guest PyAri Posted June 22, 2007 Share Posted June 22, 2007 resetting the ecu didn't work... my antenna and power steering works. Any other suggestions? Link to comment Share on other sites More sharing options...
