lui Posted June 20, 2007 Share Posted June 20, 2007 Apexi SAFC II bargain at only 85.00 + p&p Just a liitle scuffed around egdes of casing where it was mounted in a special made to measure pod but all in perfect working order. Was going to use it for myself but brought a Apexi Neo instead so no longer needed. There is also no stand included as shown in pic below. Can bring down to Jap Show at Santa Pod this Sunday if anyone interested to save on postage. Description: DIGITAL SUPER AFC II New Generation Piggyback Fuel Computer The SAFC-II is a fuel computer that adjusts air/fuel ratio by modifying the air flow meter/MAP sensor signal. The S-AFC II Features a user-definable, twelve-point, adjustable fuel curve that can be set in 200 RPM increments. The range of fuel adjustment is +/- 50% at each of these user-defined setting points. On hot wire vehicles, the Deceleration Air Flow Correction Function is capable of curing the erratic idle and stall problems associated with open atmousphere blow-off valves on hot-wire airflow meter systems. The S-AFC II is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph Displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Karmann Frequency, Engine RPM, THrottle Position, and Air Flow Correction %. http://img102.imageshack.us/img102/6138/afc2qw6.th.jpg Link to comment Share on other sites More sharing options...
lui Posted June 21, 2007 Author Share Posted June 21, 2007 Link to comment Share on other sites More sharing options...
lui Posted June 25, 2007 Author Share Posted June 25, 2007 NOW SOLD To Supra ST Myster Cheers Emin mate Link to comment Share on other sites More sharing options...
