Jezz Posted June 20, 2007 Share Posted June 20, 2007 That will do for now mate, put one to side for me, if you can drop up TF great or ill come get it;) Buzz me or Steve tomorrow mate, 07779 725350. Its already out i believe, so just call if you want to come pick it up. Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 20, 2007 Share Posted June 20, 2007 Buzz me or Steve tomorrow mate, 07779 725350. Its already out i believe, so just call if you want to come pick it up. Cool, ill come get it tomorrow afternoon;) Quote Link to comment Share on other sites More sharing options...
Jezz Posted June 20, 2007 Share Posted June 20, 2007 Cool, ill come get it tomorrow afternoon;) Quote Link to comment Share on other sites More sharing options...
Joeatphr Posted June 21, 2007 Share Posted June 21, 2007 Do you have a 6spd or Auto, guessing auto with all of what has been mentioned above. Maybe you should get a 6spd. A lot stronger all around! Cheers, Joe Quote Link to comment Share on other sites More sharing options...
gaz1 Posted June 21, 2007 Share Posted June 21, 2007 Do you have a 6spd or Auto, guessing auto with all of what has been mentioned above. Maybe you should get a 6spd. A lot stronger all around! Cheers, Joe has a 6 speed just cannot find a 6 speed dif;) Quote Link to comment Share on other sites More sharing options...
jevansio Posted June 21, 2007 Share Posted June 21, 2007 Do you have a 6spd or Auto, guessing auto with all of what has been mentioned above. Maybe you should get a 6spd. A lot stronger all around! Cheers, Joe I believe it's a 6 spd Joe Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 21, 2007 Share Posted June 21, 2007 uprate the diff jamie, otherwise supra diffs will become v160 Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 21, 2007 Share Posted June 21, 2007 Do you have a 6spd or Auto, guessing auto with all of what has been mentioned above. Maybe you should get a 6spd. A lot stronger all around! Cheers, Joe Hi Joe, The car is 6 speed, already broke two manual diffs, had to fit an auto diff this this as could not find a manual diff, got any? Quote Link to comment Share on other sites More sharing options...
Alex Posted June 21, 2007 Share Posted June 21, 2007 Thought of commissioning one from Quaife? Quote Link to comment Share on other sites More sharing options...
ivan Posted June 21, 2007 Share Posted June 21, 2007 It's got to be cheaper in the long run. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 21, 2007 Share Posted June 21, 2007 Is it the crown wheel and pinion teeth failing? if so fitting something like a tightly set Cusco plate LSD in one will just make it more likely to fail. If it's got a none cushioned clutch they hammer the drivetrain. Could be something to do with the way you treat it, too Quote Link to comment Share on other sites More sharing options...
b_have Posted June 21, 2007 Share Posted June 21, 2007 Think the non-cushioned driver doesn't help Quote Link to comment Share on other sites More sharing options...
razza Posted June 21, 2007 Share Posted June 21, 2007 bet the motorists you went hammering past had a snigger on the way past the breakdown:p one of the quickest cars around sat on a flat bed again, you'll be spending more time on those things then the road soon... Hope you get it sorted once and for all. Quote Link to comment Share on other sites More sharing options...
fishman Posted June 21, 2007 Share Posted June 21, 2007 sorry to hear the bad news again, what about putting a TRD one in??? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 21, 2007 Share Posted June 21, 2007 sorry to hear the bad news again, what about putting a TRD one in??? All these LSD units ONLY replace the diff centre section, they all use the original crown wheel and pinion, which is what I assume he is breaking. Adding an uprated centre section will only compound his failure rate if that's the case, as they will transmit more shock loading and torque through the CWP. A bigger CWP means a different diff casing = major work and expense. Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 21, 2007 Share Posted June 21, 2007 Is it the crown wheel and pinion teeth failing? if so fitting something like a tightly set Cusco plate LSD in one will just make it more likely to fail. If it's got a none cushioned clutch they hammer the drivetrain. Could be something to do with the way you treat it, too Yup, everytime its the crown wheel and pinion thats failed. Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 21, 2007 Share Posted June 21, 2007 Looks like another jap show pass up for grabs if not fixed in time Dont give my ticket away Lui, ill be there. Jeff my personal recovery flatbed:D will be here in a min to take the car to TF, Greg has said he will try his best to get the car done in time:) Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 21, 2007 Share Posted June 21, 2007 Pic of the damage this time. She is on the way Greg:) Quote Link to comment Share on other sites More sharing options...
Muffleman Posted June 21, 2007 Share Posted June 21, 2007 Really is a good looking car Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 21, 2007 Share Posted June 21, 2007 Cheers bud, looking at that pic the diff might be ok this time, looks like the donut has failed:search: Quote Link to comment Share on other sites More sharing options...
fishman Posted June 21, 2007 Share Posted June 21, 2007 All these LSD units ONLY replace the diff centre section, they all use the original crown wheel and pinion, which is what I assume he is breaking. Adding an uprated centre section will only compound his failure rate if that's the case, as they will transmit more shock loading and torque through the CWP. A bigger CWP means a different diff casing = major work and expense. Cheers for that now i know lol! Pic of the damage this time. http://i30.photobucket.com/albums/c338/jamie450x/diff003.jpg As you can tell i dont no much about diffs, but that looks pretty mangled. Hope you get it sorted asap! Quote Link to comment Share on other sites More sharing options...
TheChin Posted June 21, 2007 Share Posted June 21, 2007 God damn you jamieP i hate you! Such a damn nice car Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted June 21, 2007 Share Posted June 21, 2007 Cheers bud, looking at that pic the diff might be ok this time, looks like the donut has failed:search: Yeah that looks like toms aristo coupling when that blew out on him. Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 21, 2007 Share Posted June 21, 2007 Yeah that looks like toms aristo coupling when that blew out on him. Brought two spare diffs today aswell:D Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted June 21, 2007 Share Posted June 21, 2007 F*ck sakes man you'll be swapping them more often than your oil at this rate Quote Link to comment Share on other sites More sharing options...
