madmunky Posted June 20, 2007 Share Posted June 20, 2007 Anyone able to recommend anyone who could install the electronic true twin conversion for me in the south east? Cheers Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted June 20, 2007 Share Posted June 20, 2007 Err do it your self Its easy. TBH though i would not bother as i never use my ttc and i have it switched from inside the car. Also the vsv's rattle like fook and its like driving an N/A until 4k then all at once. I hate it I prefer the sequential setup. Link to comment Share on other sites More sharing options...
madmunky Posted June 20, 2007 Author Share Posted June 20, 2007 Is there any good guides to doing it yourself? Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted June 20, 2007 Share Posted June 20, 2007 yep hold on Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted June 20, 2007 Share Posted June 20, 2007 http://www.internetwork.org.uk/ettc/ettc.htm Hope this helps..This is a very good site..Thanks heckler. Link to comment Share on other sites More sharing options...
madmunky Posted June 20, 2007 Author Share Posted June 20, 2007 Thanks looks pretty simple! Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted June 20, 2007 Share Posted June 20, 2007 It is LOL Link to comment Share on other sites More sharing options...
gaz1 Posted June 20, 2007 Share Posted June 20, 2007 remember how to put it back right too, as i will be suprised if you like it enough to keep it like that;) Link to comment Share on other sites More sharing options...
heckler Posted June 20, 2007 Share Posted June 20, 2007 http://www.internetwork.org.uk/ettc/ettc.htm Hope this helps..This is a very good site..Thanks heckler. No probs dude Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 20, 2007 Share Posted June 20, 2007 Imo its not worth going TTC by electronic means, if its not spooling up until 4,00 RPM then something is wrong! done the proper way with wired IACV and EGCV i was making 1.1 bar by 2,800 - 3,000 RPM even now with hybrids i have full boost by 3,500 - 3,800 RPM. Link to comment Share on other sites More sharing options...
JustGav Posted June 20, 2007 Share Posted June 20, 2007 TTC is bad idea generally... why would you want to use TTC over the stock seq system? But that said, there are a few guides. You will need a dual pole switch, effectively it grounds the VSV's so they don't open. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 20, 2007 Share Posted June 20, 2007 TTC is bad idea generally... why would you want to use TTC over the stock seq system? But that said, there are a few guides. You will need a dual pole switch, effectively it grounds the VSV's so they don't open. So why is it a bad idea? if thats the case why would anyone want to go single and have later spool up and have all the power in one hit, i like it because far more predictable and controllable power wise, no unannounced sideways out of wet bends, and better fuel consumption until you choose to put the boot in;) Link to comment Share on other sites More sharing options...
JustGav Posted June 21, 2007 Share Posted June 21, 2007 So why is it a bad idea? if thats the case why would anyone want to go single and have later spool up and have all the power in one hit, i like it because far more predictable and controllable power wise, no unannounced sideways out of wet bends, and better fuel consumption until you choose to put the boot in;) I perhaps should rephrase it, it is a bad idea to do TTC without any supporting modifications, ie ECU and the like. By just doing the ETTC mod you will confusing the hell out of the stock ECU which was designed to expect the twins to operate in a sequential mode. Link to comment Share on other sites More sharing options...
Class One Posted June 21, 2007 Share Posted June 21, 2007 I had mine done, but I never use it now. Link to comment Share on other sites More sharing options...
Ian C Posted June 21, 2007 Share Posted June 21, 2007 I perhaps should rephrase it, it is a bad idea to do TTC without any supporting modifications, ie ECU and the like. By just doing the ETTC mod you will confusing the hell out of the stock ECU which was designed to expect the twins to operate in a sequential mode. We've been over this a few times If you haven't got a boost controller plumbed in right and set up right you'll get boost spikes north of 1.5bar. You'll lose a lot of low down power. You can experience detonation at points where you get more dense air than the stock ECU is expecting and therefore isn't fuelling enough for. etc. -Ian Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 21, 2007 Share Posted June 21, 2007 You may even overfuel, and I suspect THAT'S one of the reason front crank seals go, and oil pumps wear out. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 21, 2007 Share Posted June 21, 2007 You may even overfuel, and I suspect THAT'S one of the reason front crank seals go, and oil pumps wear out. Thats a touch on the scaremongering's side Chris, i agree that one of the possible causes of oil pump failure could be down to heavy over fuelling, but even in TTC mode the std ECU will not over fuel any more that it will in normal sequential mode as it doesn't kick out of closed loop until after 4,000 RPM and providing both turbos are OK and boosting all should be well and as Ian says you can end up with a lean spot around there due to this. I would be inclined to also state, as you have previously said, a far more credible cause would be problems with the second turbo not working so causing to much fuel for the diminished air flow. I am 90% sure that my car had never been run in TTC mode until i got it, and that blew the front seal due to oil pump wear before i converted it, but i do suspect that it had second turbo problems before then;) Link to comment Share on other sites More sharing options...
