absz Posted October 7, 2004 Share Posted October 7, 2004 CAN ANYONE TELL ME THE BEST FUEL PRESSURE TO RUN ON TRACKDAYS, I HAVE A 6 SPEED TWINTURBO FITTED WITH TWO STOCK FUEL PUMPS ,STANDARD J-SPEC INJECTORS,E-MANAGE,PRESSURE REGULATOR,RUNNING AT1.2BAR BOOST. Link to comment Share on other sites More sharing options...
Ian C Posted October 7, 2004 Share Posted October 7, 2004 The same fuel pressure you mapped the car at -Ian Link to comment Share on other sites More sharing options...
absz Posted October 7, 2004 Author Share Posted October 7, 2004 THE CAR WAS MAPPED WHEN IT WAS RUNNING ON SANDARD BOOST AND FUEL PUMP,NOT SURE HOW THE APEXI E-MANAGE WORKS AS ITS THE FIRST GENERATION ONE DON'T HAVE ANY DATA. WAS IN THE VEHICLE WHEN I BOUGHT IT. I WAS JUST WONDERING IF THERE WAS A COMMON PRESSURE THAT WAS USED AS A STARTING POINT ? Link to comment Share on other sites More sharing options...
Jake Posted October 7, 2004 Share Posted October 7, 2004 1, Do you mean A'pexi SAFC ? The eManage is made by GReddy not A'pexi 2, Static fuel pressure should be 36psi 3, Turn you Caps Lock off! Link to comment Share on other sites More sharing options...
absz Posted October 7, 2004 Author Share Posted October 7, 2004 ITS A AIR/FUEL CONTROLLER BUT HAS ANOTHER UNIT ATTACHED TO IT ON THE OPTION 2 CONNECTION AND HAS E-MANAGE FUEL AIDER STAMP ON IT. BOTH UNITS ARE APEXI .PS WANT DO YOU MEAN BY TURNING CAPS OFF ? Link to comment Share on other sites More sharing options...
LeeT Posted October 7, 2004 Share Posted October 7, 2004 Originally posted by absxxxx .PS WANT DO YOU MEAN BY TURNING CAPS OFF ? turn the caps lock off on your keyboard as capitals are seen as shouting on here:) Link to comment Share on other sites More sharing options...
absz Posted October 7, 2004 Author Share Posted October 7, 2004 got yeah ! forgive the newboy Link to comment Share on other sites More sharing options...
