hello
gavin.starr
just bought myself a mkiv supra twin turbo import.
Only on problem so far there is no cd player or any kind of audio device in the car apart from speakers, speakers are good but not without anything to make them work. i took the old cd player out of my old car but its about 2mm to wide to fit in the double slot so currenty driving round at the moment with no music. if any one knows where i can find a cd player that will fit please let me know as im faced with a big gaping hole to oblivion in my dashboard.
cheers in advance
gav
Just to reiterate from that link...
Important Notice : If you have an airbag installed on your car make sure you disconnect the battery before you start, if you need to move the car or move the gear shifter then make sure you plug in the very top section - before you switch on the ignition, otherwise the airbag warning light will stay on permanently.
It really is a pain in the arse if you don't :D
