Will JE supra pistons fit an MR2 Turbo?
fastisnice
Supra spec first, MR2 second....
Bore MM - 86.50+.020 / 86.50+.020
Bore Inch - 3.405 / 3.405
Over Size - 0.020 / 0.020
Stroke - 3.386 / 3.386
Rod Length - 5.59 / 5.433
Comp Height- 1.338 / 1.378
Head CC - 40 / 50
Comp Ratio - 8.5:1 / 9.0:1
Dome Volume - -14 / -4.1
Gram Weight - 338 / 343
Part Number - 210384 / 162109
They also use different ring sets, the MR2 has JC4004-3405 and the Supra JC9005-3406.
No t suitable, the compression (pin) height is quite different, the Supra pistons will be 40 thou furtyher down the bore than they should be. He'll lose all sembalnce of squish, and combined with the increased dish volume his compression will be very low. Use them as boat anchors, JE pistons are good for that application :innocent:
