dave barratt Posted June 18, 2007 Share Posted June 18, 2007 Fitted cruise control ecu, motor, and steering wheel cruise light flashing when activated Do I need any other bits ie a relay to get this to work? all the oem wiring is in the car as standard Quote Link to comment Share on other sites More sharing options...
Mike_Mac Posted June 18, 2007 Share Posted June 18, 2007 There are a few relays that you will need to source. This Pdf should help id them. Please post an update if you get this working as I plan to do the same in the future too. MacCRUISE_CONTROL_SYSTEM.pdf Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted June 18, 2007 Share Posted June 18, 2007 Dave, since your car had the green multiplug and mine didnt, i assume you have a lot of these relays in place. Have a look under the engine bay fuesbox and relay box lids and see which relays are specific to cruise, and see if they are in place. Quote Link to comment Share on other sites More sharing options...
