Fargo Posted June 17, 2007 Share Posted June 17, 2007 just went for a test drive to make sure i got no boost leak after changing a couple of I/C hoses when a strange thing happened. put my foot to the floor, got up to max boost, took foot off the go pedal but the car kept on going, had to switch off ignition to stop the car. i checked the throttle cable and pedal and all are in there rest/idle position. started car again and still revs to redline. had to do a bit of start car, into D go for a bit, switch off and coast in N.. any ideas. Quote Link to comment Share on other sites More sharing options...
Steve Posted June 17, 2007 Share Posted June 17, 2007 Is the throttle under the bonnect jammed open? Quote Link to comment Share on other sites More sharing options...
Fargo Posted June 17, 2007 Author Share Posted June 17, 2007 do you mean the butterfly valve at the end fo the TB just before the i/c pipework connects to the TB, ,this is in an open position. otherwise the throttle cable etc are all in the rest/idle position. Quote Link to comment Share on other sites More sharing options...
Steve Posted June 17, 2007 Share Posted June 17, 2007 Its the valve nearest the plenum ( should be closed with a small gap at the bottom when turned off/idling ) the one at the front is for the traction control, which should be open. Quote Link to comment Share on other sites More sharing options...
Fargo Posted June 17, 2007 Author Share Posted June 17, 2007 some pics. when i pushed this down as far as i could the RPM does drop, should the lever be touching, does it look right Quote Link to comment Share on other sites More sharing options...
Steve Posted June 17, 2007 Share Posted June 17, 2007 No pictures Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted June 17, 2007 Share Posted June 17, 2007 Looks like the TPS Have you done ANYTHING to the car recently, anything at all? Quote Link to comment Share on other sites More sharing options...
Alex Posted June 17, 2007 Share Posted June 17, 2007 Is the peddle stuck cause of the floor mat? Sounds mad but it's happened before. If that's not it then take the back hose off the front of the TB, and check the butterfly movement. Quote Link to comment Share on other sites More sharing options...
Fargo Posted June 17, 2007 Author Share Posted June 17, 2007 replaced the i/c hose that connects to TB, also the pipe in the pic to the right of the TB i had removed and put back as i didnt have enough replacement hose. yes checked floor mat also, as i said the cable is in the rest positionm ie slack Quote Link to comment Share on other sites More sharing options...
Steve Posted June 17, 2007 Share Posted June 17, 2007 remove the i/c pipe and see if the second valve behind the first(trac valve) is stuck open. Quote Link to comment Share on other sites More sharing options...
Fargo Posted June 17, 2007 Author Share Posted June 17, 2007 so the 2nd valve should be completly shut with engine off, yes. getting dark now so will have to look tomoorrow. ta for help so far guys, keep it coming. Quote Link to comment Share on other sites More sharing options...
Steve Posted June 17, 2007 Share Posted June 17, 2007 there will be a little gap with the engine off, but it should not be fully open. Quote Link to comment Share on other sites More sharing options...
Fargo Posted June 17, 2007 Author Share Posted June 17, 2007 ta Quote Link to comment Share on other sites More sharing options...
Alex Posted June 17, 2007 Share Posted June 17, 2007 yes checked floor mat also, as i said the cable is in the rest positionm ie slack The cable shouldn't be slack...it should be taught at all times. Quote Link to comment Share on other sites More sharing options...
Fargo Posted June 17, 2007 Author Share Posted June 17, 2007 The cable shouldn't be slack...it should be taught at all times. bad choice of words then, its not slack and its not being pulled,ie its in rest position. Quote Link to comment Share on other sites More sharing options...
colsoop Posted June 18, 2007 Share Posted June 18, 2007 What happens when you disconnect the throttle cable from the throttle body ? Quote Link to comment Share on other sites More sharing options...
Fargo Posted June 18, 2007 Author Share Posted June 18, 2007 sorted, in the daylight i could see. took the i/c pipe off the TB looked down it past the first butterfly and what do i spy. left over rubber hose from the old i/c hose.. Quote Link to comment Share on other sites More sharing options...
Golddigga Posted June 18, 2007 Share Posted June 18, 2007 just went for a test drive to make sure i got no boost leak after changing a couple of I/C hoses when a strange thing happened. put my foot to the floor, got up to max boost, took foot off the go pedal but the car kept on going, had to switch off ignition to stop the car. I bet that was a brown pants moment Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 19, 2007 Share Posted June 19, 2007 sorted, in the daylight i could see. took the i/c pipe off the TB looked down it past the first butterfly and what do i spy. left over rubber hose from the old i/c hose.. The engine would have LOVED eating that.... Quote Link to comment Share on other sites More sharing options...
joeblitz Posted June 19, 2007 Share Posted June 19, 2007 hi i had a simular problem last year ...it turned out a bolt had got through the throttle body and lodged just before the inlet valve ...close one .... so remove the intercooler pipe and have a look and done start the engine Quote Link to comment Share on other sites More sharing options...
imran Posted May 30, 2011 Share Posted May 30, 2011 hi mate my toyota supra is doing the same thing can you help me Quote Link to comment Share on other sites More sharing options...
