Mike_Mac Posted June 17, 2007 Share Posted June 17, 2007 Hi, As per title really. I was accelerating down a slip-road today and there was a quick high-pitched hissing noise just as the engine went through 4000 revs. It happens every time when revving past that precise engine speed. It also does it when stationary too. No other signs or symptoms. I'm slightly concerned, but I'm hoping its a hose or pipe leak? If so any thoughts as to how to narrow it down? Thanks in advance. Link to comment Share on other sites More sharing options...
AndrewOW Posted June 17, 2007 Share Posted June 17, 2007 Sounds like my problem. I would've thought it was a split hose. Mine just wheezes loudly at any boost, so I think mine's a big obvious split! No power. Horrible! Hope you get it sorted easily. Link to comment Share on other sites More sharing options...
TrickTT Posted June 18, 2007 Share Posted June 18, 2007 If its only happening above 4K rpm it must be second turbo related. I'd start by checking the 2 concertina hoses that run parallel with the camshaft cover. Link to comment Share on other sites More sharing options...
Ric Posted June 18, 2007 Share Posted June 18, 2007 reed valve top plate, check the 4 nuts on the square valve on the stream of T2 Link to comment Share on other sites More sharing options...
Mike_Mac Posted June 18, 2007 Author Share Posted June 18, 2007 Cheers guys - I'll have a look when it stops pissing it down! Link to comment Share on other sites More sharing options...
jaymdee Posted June 18, 2007 Share Posted June 18, 2007 reed valve top plate, check the 4 nuts on the square valve on the stream of T2 Bit of a highjack, but also a This may also be my problem, as I get a wooshing type noise, but only above 4000, when T2 is online. Unfortunately Ric I'm not sure what part you are referring to. Any pics?? cheers Link to comment Share on other sites More sharing options...
