Definitive weight reduction thread
uzthedentist
Thought id set up a thread for all those people whom are stripping their supes for track/drag/drift or even street. In this thread you can put what modifications you have done what lighter batteries etc and what you think of the mods. Hopefully mine wont be the only post lol
ill start, stripping mine for street and track, so still has to be drivable ;)
Removal of rear seat (2 piece)
Removal of rear seatbelts
Removal of front seatbelts and replacement with harnesses (minimal weight reduction)
Removal of spare wheel
Removal of jack
Removal of rear styrofoam and tool kit
Replacement of both cats with aftermaret downpipe
Replacement of stock exhaust with HKS Hiper Muffler (SS)
Replacement of steering wheels with 320mm aftermarket wheel (minimal weight saving)
Removal of rear subwoofer
Removal of Factory amp and ancillaries
Replacement of stock seats with fibreglass BRIDE bucket seats
Removal of under radiator cover
Removal of Glovebox and replacement with Carbon plate
Replacement of standard aluminium bonnet with CF Abflug bonnet
Removal of Air conditioning pum and ancillaries
Anyone using a lightweight battery? whats the best one to use in your experience?
  • Replies 50
I havnt done any lightening as such but i cant tell how much difference it makes when you remove the spare wheel, it makes a big difference i think, also little things that you wouldnt think made much of a difference like a different exhaust, i think its important to take note of the weight of these items before purchase, ive just had a HKS carbon fitted. Sounds light huh but no i dont think its as light as my old Trust exhaust and makes a difference to the supra performance, particularly off the line.
Hi UZ, thought I'd add my steps taken so far....
Done :
Removal of jack
Replacement of stock exhaust with HKS Super Dragger ( heavy - titanum full system would be better )
Single conversion ( but added FMIC/oil cooler )
Fluidine Rad ( possibly lighter )
KAD brake conversion all round - considerable saving over UK brakes
Removal of Front active spoiler ( with motors etc )
Removal of Charcoal canister
Removal of full stereo system
Removal of all interior trim ( except dash )
Removal of carpet and mats
Empty washer bottle :)
Going to do shortly...
Rear wiper
Ariel
Replacement of steering wheels with 320mm aftermarket wheel ?
Replacement of OEM Recaro seats with fibreglass Race seat .. and they're not for sale :)
Considering ...
Dry battery placed in passenger side seat location ( or there abouts ) - Chris has recommended Red Top 40 or 30 which are 12.5/9.0 kg
Not Considered ...
Removal of under radiator cover - 'cos I don't know what this is!
Removal of Air conditioning pump and ancillaries - 'cos I like air-con :cool:
As its not going to be a trailer queen, I'll be keeping the 'safety aspects' of the car.
I'll update this as I go along, as I've got some testing to do at Brands Hatch next week....
BTW - anyone know what the minimum fuel tank level is for track use before starvation occurs?
The Braille battery comes in at 5.5kg, recommended if you dont have ice, the aluminium front chasis collision bar is a couple of kg as well as the dreaded charcoal canister, clear up all the wiring too
I have also removed rear windscreen wiper and aerial
Rear speakers
Probably subsided with the weight of water meth injection and nos though
I have taken the 5l washer fluid bottle to behind passenger seat, you want all uneccessary stuff either binned or between the wheels
I have had Supras in here with at least 2 different carbon fibre bonnets and both were considerably heavier than the stock one!
Yep - I reckon mines the same weight, but I went for it because of the vents to get rid of heat build up.
Have a look at this:
http://www.mkivsupra.net/vbb/showthread.php?t=106834&highlight=weight
Here is what I have done:
Rear seat removed (2 pieces)
Rear seat belts
Load of plastic bits
Space saver and all tools
All speakers
Front seats replaced by fibreglass sparco seats
I have kept the front seat belts as I cant be bothered driving everywhere with a harness on
Considering:
Door cards (might be going, I have carbon door cards)
Moving the battery to the rear or behind the front seats
Carpet
Unsprung weight is also important:
Wheels (volk 18") - significantly lighter than stock 17s
Coilovers
Brake calipers and discs
Can't believe no-one has mentioned the 15-20 kilos of tar sound deadening thats stuck to the floor under the carpets.
When I do mine I'll try and get some example weights.
My mk2 supra weighed in at 1200kg dead on, from about 1315kg,
after I removed all the interior trim (except the main dash, doorcards and front seats which were still stock) engine damper and ALL the A/C system removed (including the evaporator under the dash), all the tar sound deadening, all the stereo, amp and all speakers, charcoal canister.
Could have got lighter, had I replaced the seats with buckets, polycarb'd the windows, removed the bumper support bars, etc etc.
Good quality Fibreglass bonnets are the way to go, my Shiftsports Bonnet has the oem hooks for the latches and my abflug nosecone sits a couple of mm above the front of the bonnet, aerodynamically sound:)
I've replaced the bonnet, boot lid & doors/door cards with carbon fibre.
I'd say the bonnet is the same weight, if not a touch heavier, but the doors and especially the boot are seriously lighter. I keep meaning to get to a weighbridge and find out what the difference is, but haven't had the time yet.
Where did you source carbon doors, and what do they weigh? Thanks.
Where is all this sound deadening??
I have had most of the interior out, and saw very little...
They came from the Future Motorsports group buy, but MVP are probably the best bet. Unfortunately, I didn't weigh them before they got fitted as everything went straight to the bodyshop for painting & fitting.
I'll be wanting my geometry setting-up soon, so you can have a shufty at them then.
Even with the glass back in and the stock wing fitted, the boot lid is probably half the weight of the original.
have u got a lexan rear window mate? this cf rear hatch thing is something im considering
