Braking Problem
PhatB
MOT time again :( luckily my car only failed on one thing and that was the front brake application was uneven.
The tester told me that when the brakes are applied the one takes longer to push the pad to the disk. When the brakes are released they release at the same rate.
Has anyone else had this problem? If so is it just a case of cleaning the piston or could it be something else? If it is the piston is it easy to remove?
Any help would be grateful thanks :)
