PhatB Posted June 15, 2007 Share Posted June 15, 2007 MOT time again luckily my car only failed on one thing and that was the front brake application was uneven. The tester told me that when the brakes are applied the one takes longer to push the pad to the disk. When the brakes are released they release at the same rate. Has anyone else had this problem? If so is it just a case of cleaning the piston or could it be something else? If it is the piston is it easy to remove? Any help would be grateful thanks Quote Link to comment Share on other sites More sharing options...
ukApache Posted June 20, 2007 Share Posted June 20, 2007 are they UK or j-spec? sounds like you need to refurb the caliper. you might as well get a refurb kit from toyota, straight forward to do yourself, should only take a few hours. Quote Link to comment Share on other sites More sharing options...
