Has anyone with either an N/A or a stock VVT-i had oil pump seal failure??
Chris Wilson
Surely to contaminate the oil to the degree of causing damage to the oil pump via dilution, not only would the mains, big ends and bores/rings show signs of wear/damage, but i would have thought it would take far more over fuelling than the 9-10 AFRs that the std fuelling system is capable of delivering on the MAP equipped Supras.
The pump isn't very robustly designed from a wear point of view, I believe it's the first item to wear when oil is fuel contaminated. This wear would go unnoticed, from a pressure and engine operating point of view if it were not for the very small drainage provisions, once oil starts weeping in quantity past the rotor to cover land area.
People measure AFR's passionately at WOT, but I have seen some totally bizarre AFR's with various add on gizmos at other throttle openings, even at idle. That's not to say I haven't also seen bizarre;y rich AFR's at WOT, too ;) Failure of the sequential set up to work as designed on MAP sensored engines gives a very rich mixture, which I believe to be another cause of this failure. I stand by my theory :)
