nic_f Posted October 1, 2004 Share Posted October 1, 2004 I need a new battery, I have a bit of ICE in the car. Any suggestion on the best battery to go for. Thanks Nic Link to comment Share on other sites More sharing options...
dangerous brain Posted October 2, 2004 Share Posted October 2, 2004 You tried searchin through the ICE section or asking matt harwood at sextons directly? Link to comment Share on other sites More sharing options...
stt Posted October 2, 2004 Share Posted October 2, 2004 A standard battery should suffice unless you are running serious ice in which case go to your local car audio place but thesies are around £250 each! Link to comment Share on other sites More sharing options...
dangerous brain Posted October 2, 2004 Share Posted October 2, 2004 or you could always get a higher rated battery than the standard one. I beleive serious ICE'rs use capacitors an all that jazz as well though don't they? More an ICE question than a technical one really. Link to comment Share on other sites More sharing options...
nic_f Posted October 4, 2004 Author Share Posted October 4, 2004 Ok Another Battery Related question. Why are my j-spec battery terminals different to a uk spec car, and arethey easy to change? Ta Nic Link to comment Share on other sites More sharing options...
Jason Posted October 4, 2004 Share Posted October 4, 2004 I've got a 1 Farrad powercap and an Exide heavyduty battery for my car. I had to put extensions onto the terminals to make it fit. I would go for an Optima Yellow Top battery, these can be bought with terminals either side and they fit nicely where the original battery carrier is. Link to comment Share on other sites More sharing options...
nic_f Posted October 4, 2004 Author Share Posted October 4, 2004 Hi Jason, What does the power cap do, I've always wondered? CHeers Nic Quote Originally posted by Jason I've got a 1 Farrad powercap and an Exide heavyduty battery for my car. I had to put extensions onto the terminals to make it fit. I would go for an Optima Yellow Top battery, these can be bought with terminals either side and they fit nicely where the original battery carrier is. Link to comment Share on other sites More sharing options...
Jason Posted October 4, 2004 Share Posted October 4, 2004 It basically stores a small charge so that when the system hits a large bass note, the amp(s) doesn't take power directly from the battery. You don't get fading headlights/dashboard when giving the stereo what for! Link to comment Share on other sites More sharing options...
tbourner Posted October 4, 2004 Share Posted October 4, 2004 Quote Originally posted by nic_f Ok Another Battery Related question. Why are my j-spec battery terminals different to a uk spec car, and arethey easy to change? Ta Nic My battery was shite, only a 30Ah one. Had to get the terminals on the lead changed to fit onto the new battery I bought, also had to bodge the bracket across the top to fit over the wider battery. New terminals were £6, battery was £65, fitting was £35. Link to comment Share on other sites More sharing options...
suprastorm Posted October 5, 2004 Share Posted October 5, 2004 mates got some optima yellow tops . £100 each Link to comment Share on other sites More sharing options...
Barnstormer Posted October 6, 2004 Share Posted October 6, 2004 just had my battery go as well. Popped down to Halfords as I can walk there and was totally surprised to find a lad in the shop who knew all about J-spec Supras. Anyway, fixed me up with one of their own brand ones model HB054 which is a heavy duty one. It fits perfectly to the stock connectors and is also a perfect fit in the battery compartment. Even better £40 with a 3 year warranty. Took me 2 mins to fit and works a treat. Just been up to Chris Wilson's place for some stuff and even he said it fitted and looked good. ATB Link to comment Share on other sites More sharing options...
