bromy Posted December 24, 2008 Share Posted December 24, 2008 The light should not be flashing, mine did this and IIRC you have to turn the ignition key off and on and mess with the wastegate setting switch on the back of the control box until there is a constant light. Link to comment Share on other sites More sharing options...
bromy Posted December 24, 2008 Share Posted December 24, 2008 Yep, try this. Until you get rid of the flashing light your boost will be out of control, it was on mine Turn the ingition ON but dont start the car If the controller turns on during the ignition then power it off with the PWR button on the display. Then put the switch back to SW mode (internal gate) PWR it on PWR it off then put the swtich to PO mode (external gate) Then PWR it on This should get rid of the flashing red power button Link to comment Share on other sites More sharing options...
Anees Posted December 24, 2008 Share Posted December 24, 2008 Finally cracked it!!! Even though my switch said SW on the back, on the screen it still said --P--; I tried advice given to me on supra forums about changing the boost controller over to SW (internal wastegate) mode and despite the switch on the back being set to sw (which I believed meant, the boost controller wouldn't go into --S-- mode. I kept trying with the following: So try this....Turn ignition off and make sure the SW-PO switch is in PO position. Then turn ignition on and switch the EVC OFF--now flip the svitch over to SW position and then turn the EVC back on and leave ignition on 4 min 10sec. Also when turning back on see if the display shows --SW-- lefthand corner. If this is ok,start out with the "a"button at zero and go 4 a quick pull to see what your max boost is, if boost is to high (say your base boost is 0,8BAR) offset should be increased, and if boost is to low first try to just increase the a button 50% should increase boost from say 1bar to 1.5bar Adjust at max 20% each time. I had no way of controling my boost properly before i read the EVC manual twice:) I also was thinking that the red flashing light was ok hehe and that my switching of the SW-PO switch was correct..When i did "above" i all of a sudden had the perfect boost controller:) I carried out the above advice a few times and everytime in the top left hand corner I saw --P-- even with the switch on SW at the back, but I kept trying and FINALLY it said --S-- and it now appears to be working!! I have left Mod A at 0% which equates to 0.9-0.95 bar (basically stock) I have set Mod A to 42% with equates to 17.4psi (I will fine tune this so I can get it set to 18psi) THANK YOU AGAIN FOR ALL THE HELP, especially Tricky-Ricky for the patience! Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 24, 2008 Share Posted December 24, 2008 No problem mate, glad you finally got to the bottom of the problem, it's good that somebody who has one fitted came in with a knowledge of its quirks:) Link to comment Share on other sites More sharing options...
Zofix Posted January 9, 2009 Share Posted January 9, 2009 What size vacuum caps do you need and how many? Can't find anyplace to buy them:S Link to comment Share on other sites More sharing options...
