Help Installing HKS EVC 5
madmunky
  • Replies 54
Yes mate, cant believe it all now really car flys now and pulls like a train, done 170mph on my test strip and wasnt even pushing it just got me a little scared so slowed down as never been that fast before.
Tried the car now in both Seq and Par mode and prefer Seq a lot more fun, in Par mode when both actuators are open it just makes the exhaust sound like its blowing not too keen on the noise.
  • 1 year later...
Right AFAIK the HKS solenoid is marked
B = 1 which goes to the plenum.
I = 2 which goes to pressure reference source/turbo.
O = 3 which goes to the actuator.
Maybe this will help more.
I have been trying to install a HKS EVC5 to my Aristo and am confused. In the diagram it says O goes to the pressure reference source and I to the actuator, yet in the text (post 26) its the other way round?
Any help appreciated?
Also, basic question here, but if the Boost controller is only pumbed into the turbo at the front, how can it control overall boost? Surely with two turbos their are two actuators and two wastegates?
Think you're reading it wrong, and getting confused, first off, its only the first turbo wastegate that controls the boost for both turbos, due to the way the sequential system works, so forget the pipework for the second,
Both diagrams/lists are the same.
I = is the reference source for the boost controller, which comes from the first turbo pressure side.
O= goes to the first turbo actuator, there are two ports on this, one of which must be blocked off.
B= is another reference for the boost controller from the plenum.
Thanks for the help so far but something doesn't appear to be right :(
I keep getting run away boost when the second turbo comes online and have hit as high as 20++psi before I noticed. The Boost controller is set to warn at 125KPa (1.25bar) and I wanted to have two boost settings 100Kpa (1bar) and 120KPa (1.2bar) but everytime I try and go for a run the car makes alot more boost :(
I have taken some pics and of what I have done, could someone please take a look and see if they are correct. I am wondering if I have port O and I plumbed the wrong way round?
http://www.ranatech.co.uk/aristo/hksboost1.jpg
http://www.ranatech.co.uk/aristo/hksboost2.jpg
http://www.ranatech.co.uk/aristo/hksboost3.jpg
Can anyone spot what I have done wrong?
Thanks,
Anees
Thanks for your patience mate!! This is the first time I have ever had a go at doing something like this! :)
I will try and get some caps locally today and cap everything off properly. If I can't find any then would, adding a bit of silicone pipe with the end blocked off do the same thing?
I was looking last night at Supra forums and found some with a really useful post where they had taken step by step pictures of their HKS EVC install. The thing is they had their Port O and Port I connected the oppositve way round to mine..
Post #20
http://www.supraforums.com/forum/showthread.php?t=184231
Edited by Anees (see edit history)
Boost Controller setup was halted today when I opened the bonnet and saw this:
http://www.ranatech.co.uk/aristo/broken.jpg
Nursed the car home again and today I decided that rather then get a stock part from Toyota I'd rather get some reinforced Silicone Hose to replace it.
Decided on a 90 degree elbow reducer (76mm - 63mm), a 45 degree 63mm elbow and two aluminium metal hose joiners; oh and some jubilee clips and a super strong T-bolt clip. Excellent Service and help from Auto Performance Silicone in West Yorkshire :D
Got home and compared to my standard part and started joining my pipes together:
http://www.ranatech.co.uk/aristo/stock.jpg
Cut them down:
http://www.ranatech.co.uk/aristo/cutdown.jpg
After some playing and tightening up the hoses I think it looks rather good and I have peice of mind that pipe aint going anywhere!!!
http://www.ranatech.co.uk/aristo/fitted.jpg
I also used some hair spray on the inside of the silicone hose (which is a tip I read about).
Hopefully I never have problems with that pipe again!!
Now to get this Boost Controller functioning properly!
Anees :D
http://www.componentforce.com/en/index.php?pagecode=productcategory&id=32
thats where i got my caps from anees, they provided me with some samples for work (ahem) as i couldn't find anywhere to get caps from locally
Cheers mate. I tried every local motor factor (thats 5 including Halfrauds) for some caps and no one had anything :)
I willl just use a bot in a piece of silicone pipe for now, but I'll order these to make everything neat once I know the boost controller is working properly.
:help:
Still not working.
/vbb/images/smilies/bbcode_sad.gif
I am getting fed up with it all now! :giveup:
Today I made sure all my connections were neat and I capped things off alot better
http://www.ranatech.co.uk/aristo/vsv1.jpg
http://www.ranatech.co.uk/aristo/vsv2.jpg
But no matter what I do the car still seems to overboost when the second turbo comes on. I have set both mode A and mode B to zero 0 which should be a 0% increase over the stock baseline boost setting but I still get very high boost. My car has one decat in and a 3" Catback exhaust, and before boost controller was installed boosted to about 0.9 - 1.0bar.
I am beginning to think the boost controller is faulty; even if I change the hoses for Port O and I over, do a master reset the boost controller still doesn't hold boost.
I also wanted to ask people that have a HKS EVC5 if the flashing red power button is normal when the controller is powered on?
http://www.ranatech.co.uk/aristo/redlight.jpg
Does it indicate a fault??
The manual also mentions adjusting the boost offset, which I am supposed to be able to get into by pressing MOD for more then 1 sec from the main screen so I enter the display settings mode and then press MOD again for more then 1 second. Everytime I do this the boost controller does not go into offset; it moves onto a different screen. Grrr!!!!
I have read the manual and followed the steps it suggests with no success.
I really don't want this controller to be faulty, because I have the screen nicely fitted inside my ash tray after hacking my ashtray to make it fit! :( :( :(
