Oil Pressure/Temperaure Readings
Steve
Sump plug for the temp sensor.
The Lexus bolt thingy for the pressure sensor, on the later cars they already have this bolt or you can buy a Lexus one or tap the one you already have .
A search will reveal all. :)
Difficult to tell from that pic, but the LMA one was brass, and was drilled all the way through, which meant that the wall thickness of the thread that screws into the sump is only 1mm:( so IMO wont take the torque of being done up properly, if the Blitz one is steel it should be a little better even if it is of the same design.
