lockys96 Posted June 9, 2007 Share Posted June 9, 2007 i changed my rear lights to the facelift ones, iv had the foglight mod put in before and it worked fine. the problem now though, is when i switch the fog light on, it lights up one of the reverse lights!!!! what the hell could be different, i thought it would just be plug in and play Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted June 9, 2007 Share Posted June 9, 2007 Si, If I'm down tomorrow sorting my Figgy's then I'll take a look at it for you mucka. It sounds as if the +ve power from the fog light switch is feeding directly in to the closed loop circuit of the light cluster;) Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 9, 2007 Author Share Posted June 9, 2007 seems weird, as all i did was change the lights. cant see why the loom would differ, its hard wired into there somewhere Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted June 9, 2007 Share Posted June 9, 2007 seems weird, as all i did was change the lights. cant see why the loom would differ, its hard wired into there somewhere My drill, sledge hammer, chisel and grinder should sort that out easily mate Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 9, 2007 Author Share Posted June 9, 2007 oh shut up, u break, you pay. ure not short on cash, unlike some of us. i must hold out buying anthing for at least 2months. although its very difficult Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted June 9, 2007 Share Posted June 9, 2007 oh shut up, u break, you pay. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 29, 2007 Author Share Posted June 29, 2007 right, it apears the old pre-facelift rear lights had a red bulb fitted to one of the reverse lights, making it a fog light when switched on. the facelift bulbs have slightly different connectors, so i was wondering where can i get a replacement bulb, BUT IN RED? SI Quote Link to comment Share on other sites More sharing options...
squiffy Posted June 29, 2007 Share Posted June 29, 2007 ebay is always a good bet, every type of bulb you could ever want on there! Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 30, 2007 Author Share Posted June 30, 2007 im not sure what bulb they take. very wierd ones Quote Link to comment Share on other sites More sharing options...
lockys96 Posted July 1, 2007 Author Share Posted July 1, 2007 bump Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted February 11, 2008 Share Posted February 11, 2008 Sorry to ressurrect this - but I am in the same boat. Need a new "fog light" which is actually a reverse light in a facelift, but painted/coated RED Did you get anywhere with this? Quote Link to comment Share on other sites More sharing options...
QSC Posted February 11, 2008 Share Posted February 11, 2008 What you do is search for foglight conversion mod & convert your inner brake lights to work as fogs. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted February 11, 2008 Share Posted February 11, 2008 What you do is search for foglight conversion mod & convert your inner brake lights to work as fogs. Sorry, I already have the mod, but the bulb needs replacing, that's all. It's a very weird bulb Quote Link to comment Share on other sites More sharing options...
QSC Posted February 11, 2008 Share Posted February 11, 2008 That snot what I mean - the proper mod doesn't convert a reversing light, it converts two of your brakelights into fogs, then you don't need a red bulb Quote Link to comment Share on other sites More sharing options...
