lockys96 Posted June 8, 2007 Share Posted June 8, 2007 all sorted Link to comment Share on other sites More sharing options...
Terminator Posted June 8, 2007 Share Posted June 8, 2007 So sorry you have been the victim of shoddy workmanship. The welding on the end of the exhaust has ruined it. I would only accept a replacement. Choose carefully who you get to do the work. Link to comment Share on other sites More sharing options...
gaz1 Posted June 8, 2007 Share Posted June 8, 2007 looks wierd the way the rubber is in the middle:blink: Link to comment Share on other sites More sharing options...
Ric Posted June 8, 2007 Share Posted June 8, 2007 would this not be better in dispute? where nobody can start on a bandwagon/witch hunt.... Link to comment Share on other sites More sharing options...
lockys96 Posted June 8, 2007 Author Share Posted June 8, 2007 all sorted. Link to comment Share on other sites More sharing options...
mr lover Posted June 8, 2007 Share Posted June 8, 2007 good Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 8, 2007 Share Posted June 8, 2007 TBH its very hard to weld a hanger to an exhaust pipe without it being a compromise, admittedly the first pic looks a bit messy but a large part of that is down to it not being cleaned up afterwards, also its practically impossible to weld something thin and not get makes on the inside, if there isn't any marks then i would say that there isn't adequate penetration, so its liable to fall off! the others don't look terrible, and i see why the middle pic looks confusing as its been done to provide damping from side movement which will sometimes cause a knock. Link to comment Share on other sites More sharing options...
Terminator Posted June 8, 2007 Share Posted June 8, 2007 would this not be better in dispute? where nobody can start on a bandwagon/witch hunt.... No witch hunt intended, if any trader did this to an exhaust, it would still be the same. Just told it like it is, shoddy workmanship. Link to comment Share on other sites More sharing options...
Ric Posted June 8, 2007 Share Posted June 8, 2007 No witch hunt intended, if any trader did this to an exhaust, it would still be the same. Just told it like it is, shoddy workmanship. i wasnt directing that at you, just in general, this board seems to pick up speed with them very quickly for some reason Link to comment Share on other sites More sharing options...
Class One Posted June 8, 2007 Share Posted June 8, 2007 Seeing as the matter appears to be sorted between the thread starter and Turbofit, the matter is closed on this thread. Link to comment Share on other sites More sharing options...
