dandan Posted September 27, 2004 Share Posted September 27, 2004 I have a relatively straight forward question which I hope will yield a simple answer. I can't lay my hands on my Clifford handbook and was wondering what to do once you've changed the batteries in a keyfpb to get it working again?? I still have one working remote, how do I get the 2nd wrking again? Also anyone know how you disable your alarm if your keyfobs stopped working? Cheers Dan Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 27, 2004 Share Posted September 27, 2004 The remotes should work straight away after changing the batteries. Chances are, the battery terminal has come off the PCB. Open up the remote, and look at the clamp that goes around the battery. It should have a locating lug that should be soldered to the board. It's not uncommon for them to break off. As for disarming the car without the remotes. Simply enter your valet code with the keys in the ignition, switched to the ignition position. Quote Link to comment Share on other sites More sharing options...
dandan Posted September 27, 2004 Author Share Posted September 27, 2004 Thanks Matt, I'll have a look. We need to have a chat about meeting up at some point. After this upcoming weekend I'm pretty flexible, back home now too.............FAR TOO COLD!!! Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted September 28, 2004 Share Posted September 28, 2004 when i went to take my car to get it checked up by alarm installer he found my battery connection had come away from the board and he solderd it back on. the battereys are only £1 each did you know you supposed to get your alarm in once a year for check ups, thats what alarm bloke was telling me, something to do with insurance. matt how muc are glass tamper things for the clifford. it looks like a small thin strip that sticks onto window? Quote Link to comment Share on other sites More sharing options...
