boost/missfire.... yes i no i no (tns. I know I know)
D8MOA
i no can of worms/are we covering this again/RTFM/ search botton!! yes its all been done!!
i have a missfire bit of a strange one so i will explain...
when the car was on the road i had boost missfire problems but ime guna decribe it the best i can..
when its warm and at idle if i rev it slowley it will rev fine all the way up to redline BUT if i boot it quick it will go up to about 1k off redline and start missing/spluttering...
the car has new coilpacks/plugs and coil connectors so ime ruling them out...
could it be a vsv/accuator problem?
also what would happen if the 2nd turbo impeller had broken off?
its a j spec auto.all the ic hoses are fine as ive just refitted them
did you refit and then it started happening, or were they refit after the missfire??
fuel pump?
possibly, low pressure would cause a lean missfire....certainly something you dont want to be seeing, I would also check your pump while your about it
