Problem again. lol
markiemark
Hi there every one.
I am having a problem. i have changed the power steering unit and changed the fuild. as i throught this was the problem. but it still the same.
the problem is the streeing is very heavy and a loud noise from pump area. but as the pump has been changed i am confused. any ideas.
i am not driving her as i dont want to do any more damage. but on when it went the steering went very heavy like i had no power steering.
just a bit worried that there is expensive bill on the way.
cheers mark
i presume you have gone through the bleeding process and got all the air out of the system? having air gives a kind of rumble sound not a squeal,i just had an issue with mine squealing and tracked it down to my billet aluminium p/s pulley which had been machined with quite sharp blades not like the stock one which is more rounded, check bleeding again to be 100 percent if your unsure as it is easy to illiminate.
Did you fit a brand new pump?
It may be just air in the system, to bleed remove the cap make sure fluid is at the correct level. With cap still off and engine ticking over, turn the steering wheel from full lock to full lock a few times. This should get any air out of the system.
