tarcase Posted June 6, 2007 Share Posted June 6, 2007 What type of engine oil do you use for a non-turbo please anyone? Quote Link to comment Share on other sites More sharing options...
Golddigga Posted June 6, 2007 Share Posted June 6, 2007 Hi mate, I was advised by a mechanic on the forum to use magnatec 10 40 You will need around 5.5 litres if you are replacing the oil filter - which is obviously advisable. Set me back around £40. Cheers. Quote Link to comment Share on other sites More sharing options...
markiemark Posted June 6, 2007 Share Posted June 6, 2007 i was going to ask the same. cheers for the info Quote Link to comment Share on other sites More sharing options...
broomie Posted June 6, 2007 Share Posted June 6, 2007 Silkolene Pro S 5w-40 6.5 litres http://www.opieoils.co.uk Quote Link to comment Share on other sites More sharing options...
Golddigga Posted June 6, 2007 Share Posted June 6, 2007 Silkolene Pro S 5w-40 6.5 litres http://www.opieoils.co.uk I was originally advised to go for this but in an N/A the magnatec will be fine and a bit easier on the £ However, I believe the story is different for a TT. Quote Link to comment Share on other sites More sharing options...
neil tt Posted June 6, 2007 Share Posted June 6, 2007 If you do a search, you will find a list for all the different oils you will ever need for the car:) Quote Link to comment Share on other sites More sharing options...
Sheefa Posted June 6, 2007 Share Posted June 6, 2007 See this thread mate: http://www.mkivsupra.net/vbb/showthread.php?t=110863&highlight=oil+guide Alex also put a brilliant guide together here http://www.mkivsupra.net/vbb/showthread.php?t=56684 Looks like you really want some Fully Synthetic 5w30-10w40 (Silkolene or similar) with an interval change at around 8-9,000 miles. Greg Quote Link to comment Share on other sites More sharing options...
oilman Posted June 6, 2007 Share Posted June 6, 2007 10w-40 semi will be ok if you cange within ever 5k or so, dont bother with Magantec, over priced and not all that. A well branded 10w-40 will be just as good. Ideally though a 5w-40 synthetic and they may be cheaper then you think, we have then around £30 for good quality 5w-40 oils. Cheers Guy. Quote Link to comment Share on other sites More sharing options...
