Emanage blue, fields harness and all required bits
Homer
Greddy E-manage Blue, fully wired fields harness, greddy pressure sensor & USB cable (inc driver software).
This is everything you need ECU wise for a single conversion, or to run larger injectors on a TT setup.
It is currently setup for a Jspec TT. The fields harness wiring and EMB config has been checked by Matt Harwood and given the all-clear.
I'm looking for £350 for the lot, it cost me considerably more to put together, so this is a bargain.
Stock 6 speed ECU available separately
Hi Homer,
Any use to me on my Jspec Auto TT? Am drawn towards these fancy electronics like a magpie to shiney stuff, but not sure if they're really needed on my car.
What else would be needed to actually use it? I'm guessing a wideband sensor/unit (eg Innovative LC-1) and someone to map it...
cheers mate
  jaymdee said:
Hi Homer,
cheers mate
Hi Jon, If you're raising boost then there are good advantages to having a mapable ECU, especially if you want to push the limits of the stock turbos with a degree of safety. It'll allow you to smooth out the normal lean spot when boost is building on #2, but allow pulling some fuel once rpm is high.
You will need a wideband input (innovative or AEM/Bosch will be fine, using the flange on the decat I just sold you ;) ). Yes, it will need to be mapped. It goes without saying that Ian C is your man here.
Good price and perfect for standard, BPU and over - a well mapped eManage can save fuel and give you more power.
You don't really need anything else to go with it if you trust your mapper but boost gauge, EGT and wideband is always nice to have around :)
Do you not need a Wideband sensor to measure AFRs?
Yes, it's needed in terms of mapping a turbo car. The stock O2 sensor is narrowband so is no good for mapping a turbocharged car.
No mapper in their right mind would map one without a wideband input. Wideband sensors on their own can be picked up for a very reasonable rate, I think the innovative ones are £55. Obviously if you want the gauge to go with it you have to spend more.
Edited to add - as Michael says, if you really trust your mapper you can get away without one. Most mappers will have their own gauge they can bung up the tailpipe during the mapping session and use that to map off. Personally I'd want an AFR gauge just to keep an eye on things (goes for anyone with 1.1bar+ and BPU mods)
Non-refundable deposit taken, so this is sold pending full payment.
  chrisavila100 said:
Hi homer, could this be used on a uk spec car? and would it be worth while on a uk bpu?
Cheers chris..
Hi Chris, just for info, this is fine for use on a UK car though would need some changes to the EMB jumper and dial switches plus some wiring changes.
Yes, it's probably more worthwhile on a UK spec than jspec, due to the bigger injectors and steel exducer ;)
