my single install
supra matt
Well there are so many single projects on hear at the moment : ill skip the hole right up bit and just give you some pic to look at :D .
One or two bit's to finish like fitting the air filter and my boost controller and my fuel system , but it up and running for now :D
Nearly there ;)
Are you doing the work yourself? Any details on the spec?
*nit picking time* :D - why the HKS cam gears? It's well proven you'll never need to adjust them (unless it's an ubder tuned high output car) so seems a bit of a waste of money
Hi mate yes do all my own work from respraying to all engine work .
the turbo is a phr stage 2 i think! (i brought it off luicfer) got 650cc sard injectors to go in only running them off a apexi neo for the moment till i can afford to get a AEM ecu , i got the hks cam gear cos they look nice and only £60 so cheap + I'm going to be getting some hks cams at some point and this will allow for them to be timed up spot on .
Good on you for doing the work yourself :thumbs: It really helps understand whats going on in there!
I was going to ask if it was a PHR stage 2, looks exactly like those I've seen. Thats a 62mm turbo I think? 650's should be fine, though 1.4bar might be your safe limit.
Those gears were cheap (and look pretty :D ), but I don't think you'll ever need them in terms of the adjustment, uprated cams or not.
Looking forward to the next update. I may have mentioned it before, but whatever headache you get in the install/mapping, it's worth it :D
Nice job Matt:) your going to have to do some polishing to compliment that shiny turbo now;) just jealous really:p
Hi mate I'm going to paint the cam covers whi and the spark plug cover black then give the engine bay a good jet wash to clean it all up nice ;)
Thanks mate i really enjoy doing all my own work:D and on the plus side saves me loads of money in labour cost which i can put back into the car :eyebrows: , I'm only looking for 450 to 500 bhp so hope to see this by about 1.2 bar ? im not sure what turbo it is ? im going to sned phr a massage and ask them as i think it might be a bit big for me poor old auto, i only need a stage 1 me thinks :D
Ooh, just noticed it's water cooled, wouldn't that make it PHR 2+?
I.e much larger T67 sized?
PHR also do DBB versions of the stage 1 and stage 2 turbos. The turbo doesn't look overly big to me, looks like it could be either stage one or 2 to me.
Nice one Matt, good luck with the rest of the build :thumbs:
Nearly there ;)
I disagree with that, dan got an extra 40nm out of a supra the other day with playing about.
slight critisism mate i would look at some pucka ally tubing for the intercooler check out e-bay, it costs little and welds well (give the welder some scraps to practice on) i had trouble with cobbled together piping blowing off culminating in destroying a scooby and blowing an I/C pipe off, i didn't let the side down however as i think he thought i was playing with him as i slowed down and he was to scared to overtake:D
Great progress matt, well done!
I 'd suggest your overflow tank is in a less than optimal area. It gets VERY hot there. You can get a much smaller overflow bottle from an old Toyota in a scrap yard that will fit nicely alongside the battery.
Ya looking to get a smaller one , only temp as i got mot on sat and no time to get one till after ;)
