markssupra Posted June 3, 2007 Share Posted June 3, 2007 Just fitted hard pipe kit to rad and noticed the bloody top hose connection was cracked. Does anyone repair these rads (toyota manual shows it being done) over here or is it not worth the hassle. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted June 3, 2007 Share Posted June 3, 2007 there is a thread on exactly on this problem and how to fix it cheaply. ...time to search, ill see if I can find it. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted June 3, 2007 Share Posted June 3, 2007 Here you go, http://www.mkivsupra.net/vbb/showthread.php?t=83786&highlight=radiator+repair Quote Link to comment Share on other sites More sharing options...
markssupra Posted June 3, 2007 Author Share Posted June 3, 2007 Great repair but I'm not sure about it fixing mine. I would have to fabricate a new top hose connection and somehow fix it into place. How long it would last with the hardpipe bouncing about is anybody's guess. Quote Link to comment Share on other sites More sharing options...
Konrad Posted June 3, 2007 Share Posted June 3, 2007 New rad is not that expensive really and there is how-to on site with all pics and instructions. Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 3, 2007 Share Posted June 3, 2007 i had the exact same problem, after i clamped the hose down took the car for a spin and it was leaking by the rad, took the rad pipe off and the p clip had crushed the rad tube, i had some 25mm galv tubing in my van so cut that down and that fitted perfectly in there with a tight seal then clamped the hose on the new tubing and fixed the problem, pretty chuffed actually, plus you dont see it and it doesnt leak! Quote Link to comment Share on other sites More sharing options...
markssupra Posted June 3, 2007 Author Share Posted June 3, 2007 That may do the trick, hope there's enough left on the rad to clamp to. Quote Link to comment Share on other sites More sharing options...
markssupra Posted June 4, 2007 Author Share Posted June 4, 2007 Phoned a rad repairers in colchester this morning. They can fabricate a new top section in ally. £200 + vat. Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 4, 2007 Share Posted June 4, 2007 You can probably get a new stock rad for near that? -Ian Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted June 4, 2007 Share Posted June 4, 2007 Phoned a rad repairers in colchester this morning. They can fabricate a new top section in ally. £200 + vat. that's abit pricey if i was going to pay that i would just get a fluidine rad for not a lot more Quote Link to comment Share on other sites More sharing options...
markssupra Posted June 4, 2007 Author Share Posted June 4, 2007 Thats what I thought. Worth a phone call I suppose. If I can only get a rad for a manual, would a fluidyne oil cooler work ok for the auto trans if it was fitted in passenger side airvent? Or would it need a fan as well. Quote Link to comment Share on other sites More sharing options...
Thorin Posted June 4, 2007 Share Posted June 4, 2007 £310+VAT for stock I believe. Quote Link to comment Share on other sites More sharing options...
markssupra Posted June 10, 2007 Author Share Posted June 10, 2007 i had the exact same problem, after i clamped the hose down took the car for a spin and it was leaking by the rad, took the rad pipe off and the p clip had crushed the rad tube, i had some 25mm galv tubing in my van so cut that down and that fitted perfectly in there with a tight seal then clamped the hose on the new tubing and fixed the problem, pretty chuffed actually, plus you dont see it and it doesnt leak! Took your advice a stage further, thankyou. Cut the dodgy bits off the top hose connection and filed it back flat. Turned a new connection in ally with a very small lip on the end that fits into the rad. Only had one chance with this, so made sure all the measurements were right, applied some glue and pushed it into the rad until it clicked into place. That buggar aint coming out again.top hose Model.pdf Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 10, 2007 Share Posted June 10, 2007 yeah nice one, with the 25mm tube i fitted, it was a perfect tight fit and like yours it aint comming out! Plus know that now as driven the car quite hard and there isnt a drip comming from it! Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted June 10, 2007 Share Posted June 10, 2007 I got a fully rebuilt unit, looked brand new tbh, for less than £150, but that was for a 6 Speed and not an Auto. Quote Link to comment Share on other sites More sharing options...
