supra handling
wilko
cant believe how much difference good tyres and alignment help with handling. the supra has never held the road so well, using lance w alignment and runing bridgestone potenza re050 tyres, the results are unbelievable:)
Guest Chumpalot
I'm looking forward to driving mine with the larger tyres on... going from 17" to 19" 245/265... should handle a lot better.
just put a new set of re050-A's on mine, not had a chance to drive it properly with them on yet but I'm hoping it's going to be good :)
how much does 4wheel alignment cost approximately then? might get mine checked and adjusted too to get the most out of the new tyres
the lance w settings use less -ve camber on the front is that right ??
Have you noticed any extra wear on the outerside of the front tyres at all ??
Just wondering as I will be booking mine in for 4-wheel alignment soon and I'm thinking of sticking to toyota original.
I need to get the balancing/tracking/alignment done too. I curbed my front wheel recently and now I'm getting a lot of vibration and judder through the steering (and car in general), at motorway speeds. Anyone know of a good reputable place around Berkshire area? Oh, and somewhere that does wheel refurbs.
You'll find it worse mate. Honestly. I had 19" i-forged wheels, and the handling was awfull. I'd never go over 18" again.
i believe stock alignment is for stock wheel size, but cost me 80 quid took about an hour be prepared for seized cam adjusters i had that problem 1 year ago and they had to be replaced ...not cheap i can tell you
