Top Secret front
stylieee
Top secret front bumper.
I'm about 3/4 finished spraying it black (needs final wet-n-dry then laquer). if your a perfectionist thoghu it could do with a pro prep/respray.
its not perfect... i got it 2nd hand and at some point its been repaired (load of expanding foam inside at the bottom), but you cant tell that from the front. also theres a little bit chipped off from one of the top corners. but overall it looks realy good, and is a well made bit of kit.
also as its been on a supra before your pretty much guaranteed a decent fit right away :)
http://img76.imageshack.us/img76/4461/1000523xn8.jpg
Mate, i have had this bumper for as long as I can remember. The first one I had went on both corners - just a small dink on the curb will do it. Not a big problem at all.
On the second one I got I sprayed the expander foam in to give it strength. I would suggest this is what has happened to this. Unless you can see damage i would say it hasn't been hit, just strengthened.
Don't put it down unless you know it has happened bud - doin yourself out of a sale;)
  • 4 weeks later...
  • 1 month later...
