markiemark Posted June 2, 2007 Share Posted June 2, 2007 hi there all my power streeing unit is KO. for some reason last night it blow the pipe work off and and is now make a really wired noise. i have replaced the pipe work and topped the fluid up but still no joy. do you think it is time for a new one. sod knows what this is going to cost!!!!! just when she is was going all good and look good BUGGER any ideas cheers Link to comment Share on other sites More sharing options...
Paul372 Posted June 2, 2007 Share Posted June 2, 2007 steve manley at inchcape toyota does discounts for club member go prices give him a call 01865 291300 Link to comment Share on other sites More sharing options...
Paul372 Posted June 2, 2007 Share Posted June 2, 2007 or you can get a second hand one from jezzybabes on here, he brakes supes Link to comment Share on other sites More sharing options...
JODY T Posted June 2, 2007 Share Posted June 2, 2007 Mark Before you do this, get a long thin screw driver.. The fluid bottle has a filter inside, this gets dirty over time and then you drain the fluid it gets an airlock, that is a right PITA to get out.... IF you pierce a few holes into the filter this will alow the air to be released... Let the car tick over for 5mins, dont move the Steering wheel.... turn the car off and top up the bottle.. Do the same again untill the noise goes.... Be patient and it 'should' quieten down... Saving you having to buy a new pump and having to do the same again Link to comment Share on other sites More sharing options...
dini_the_owl Posted June 2, 2007 Share Posted June 2, 2007 The best way i found was to jetwash inside for about 10 mins till it was super clean making sure to go up from the bottom aswell,also leave it a few days in a warm place to get all the water out,as i didnt want to damage the filter in any way. Link to comment Share on other sites More sharing options...
AlanM Posted June 2, 2007 Share Posted June 2, 2007 And after you clan it out and re-fill, leave the top off, and move the wheel from full lock to full lock several times with engine running, toppping up if necessary, and then replace the cap Link to comment Share on other sites More sharing options...
