Andrew Dunk Shaw Posted May 15, 2002 Share Posted May 15, 2002 Can anyone tell me how you get the rear wing off a uk mkiv. Am i right in thinking that there bolted on as well as a double sided sticky pad. Regards Andrew [dunk] Shaw Quote Link to comment Share on other sites More sharing options...
Darrell Payne Posted May 15, 2002 Share Posted May 15, 2002 Remove the black plastic trim on the underside of the boot hatch. You'll find two black 10mm bolts either side ,once they are released the wing will have to be pulled from the top.. Its held in by two metal pins attached to the wing,which clip into plastic lugs in the body... Hope that makes sence.. Darrell Quote Link to comment Share on other sites More sharing options...
Andrew Dunk Shaw Posted May 15, 2002 Author Share Posted May 15, 2002 Thanks Darrell, Just thought i'd ask before i start swearing and throwing hammers around the workshop. Regards Andrew dunk Shaw Quote Link to comment Share on other sites More sharing options...
