Guest Vanster Posted June 1, 2007 Share Posted June 1, 2007 Hi all, Picked up my supra on Monday 95 Auto NA - 40'000 miles Im looking at doing a service just wondering where people get there servicing parts iv been looking at Japparts.co.uk and sparkplugs.co.uk also the interia bulbs on the right hand part of the dash don't light up - oil and water temps and the starter motor, doe's anyone know where i can get these bulbs from? all there don't light up so could it be a fuse? Thanks Guys. Quote Link to comment Share on other sites More sharing options...
mr keef Posted June 1, 2007 Share Posted June 1, 2007 Probably left the plug out the back when they had the clocks out for the mph conversion Quote Link to comment Share on other sites More sharing options...
mr keef Posted June 1, 2007 Share Posted June 1, 2007 And theres plenty folks on here that can get service parts see the traders...but dont use Lucifer as your post count will shoot up very fast;) Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 1, 2007 Share Posted June 1, 2007 where in west sussex are you?? im in surrey, reigate, not that far... Quote Link to comment Share on other sites More sharing options...
Nic Posted June 2, 2007 Share Posted June 2, 2007 All the lights on the RHS of the upper dash panel run off one connector. The panel is very easy to remove, 6 screws to undo on the panel and it will slide out. Check the connector, as said it is probably not attached or is loose, try wiggling the connector/wiring around with the ignition turned (engine not running) on and see if they illuminate. Quote Link to comment Share on other sites More sharing options...
loks Posted June 2, 2007 Share Posted June 2, 2007 Common problem this one. Take out the bulbs circuit board assembly and check the the solder is not cracked - you have to look very closely to see it. Either get someone to carefully solder it up or find a replacement assembly. Nic could help you with parts numbers and supply if necessary. HTH Quote Link to comment Share on other sites More sharing options...
Guest Vanster Posted June 2, 2007 Share Posted June 2, 2007 Thanks, I have had the unit out to have a look and it was all connected up, but i will have a closer look at the solder. + im down in crawley at the mo. so not far from Reigate. Quote Link to comment Share on other sites More sharing options...
Guest Vanster Posted June 2, 2007 Share Posted June 2, 2007 Also, The car came with sub standard Alloys and the guy i bought the car off said that the wheel nuts on the alloys wouldn't fit the spare wheel. does anyone know the best place to get the nuts for the standard skinny spare wheel? Cheers Quote Link to comment Share on other sites More sharing options...
carl0s Posted June 2, 2007 Share Posted June 2, 2007 Common problem this one. Take out the bulbs circuit board assembly and check the the solder is not cracked - you have to look very closely to see it. Either get someone to carefully solder it up or find a replacement assembly. Nic could help you with parts numbers and supply if necessary. HTH Two of the three Supras that I've spent time with have had this problem. It takes five minutes to re-flow the solder on the board and fixed it both times. The test is usually to tap on the display fairly hard with the key turned to ACC or something. Quote Link to comment Share on other sites More sharing options...
Guest Vanster Posted June 4, 2007 Share Posted June 4, 2007 Thanks Guys all sorted now...loose connection. Quote Link to comment Share on other sites More sharing options...
