Ryan.G Posted June 1, 2007 Share Posted June 1, 2007 I am one for keeping the standard airbox over induction cones due to the good job it does but was wondering has anyone ever fitting the standard airbox with a single turbo as in the middle of fitting my gt4088 and have loads of room to be able to fit the air box back in. Just not sure if its going to be a restriction or not in the system Link to comment Share on other sites More sharing options...
mikeyb10supra Posted June 1, 2007 Share Posted June 1, 2007 I think Wez on here has done something similar, might be worth speaking to him about it!! bloody good idea if you as me Link to comment Share on other sites More sharing options...
Alex Posted June 1, 2007 Share Posted June 1, 2007 Although I think it's a good idea, I think you're better off fabbing a shield for a 12"x6" K&N cone. Sheild it from the rad and engine, give it a good cold feed from through the filler plate behind the light. I cut a 4" hole in that plate and attached a 4" flexi hose, this sat where the SMIC used to be. The filter used to be cold at the end of a decent run Link to comment Share on other sites More sharing options...
Ryan.G Posted June 1, 2007 Author Share Posted June 1, 2007 give it a good cold feed from through the filler plate behind the light. I cut a 4" hole in that plate and attached a 4" flexi hose, this sat where the SMIC used to be. The filter used to be cold at the end of a decent run I was thinking about that last night matey Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 1, 2007 Share Posted June 1, 2007 Spend time and money on making the stock box connect with your single! Link to comment Share on other sites More sharing options...
Ryan.G Posted June 1, 2007 Author Share Posted June 1, 2007 Can you see the box and standard filter being a restriction tho chris. Will make the inlet 4" tho Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 1, 2007 Share Posted June 1, 2007 Can you see the box and standard filter being a restriction tho chris. Will make the inlet 4" tho Not at all. Link to comment Share on other sites More sharing options...
Wez Posted June 1, 2007 Share Posted June 1, 2007 I did start modifying the stock airbox but never finished, my fibre glass skills are not very good I would deff be interesting in trying again, I got round to removing the stock back, building up and shapping new back and also prepared a 4" inlet but never got it all together. Keep us posted on how you get on Link to comment Share on other sites More sharing options...
Wez Posted June 1, 2007 Share Posted June 1, 2007 Here is my old thread with some pics at the bottom. http://www.mkivsupra.net/vbb/showthread.php?t=81298 Link to comment Share on other sites More sharing options...
