wilko Posted May 30, 2007 Share Posted May 30, 2007 just wondered if anyone knew correct alignment when running on 18s current set up front castor 3 deg 46 min and 4 deg front camber minus 0 deg 37 min and minus 0 deg 41 min front toe 0 deg and 0 deg rear camber -2deg 10 min and -2 deg 12 min rear toe 0 deg and 0 deg thanks in advance for any help Quote Link to comment Share on other sites More sharing options...
wilko Posted May 30, 2007 Author Share Posted May 30, 2007 can anyone out there offer suggestions Quote Link to comment Share on other sites More sharing options...
Gazboy Posted May 30, 2007 Share Posted May 30, 2007 Email Dave Stone from DSA, he geos my car for trackwork, and it's much better than stock, but it shags tyres pdq. Quote Link to comment Share on other sites More sharing options...
wilko Posted May 30, 2007 Author Share Posted May 30, 2007 could do with set up for road use with good wear Quote Link to comment Share on other sites More sharing options...
Mike B Posted May 30, 2007 Share Posted May 30, 2007 There has been a huge amount of discussionon this, have a look in the search facility. One thing I have learned is that every car is different.. probably not what you want to hear, but I recon it's true. My advice would be to take it to someone who has a lot of experience setting up geometry and let them do their work. You wouldn't use some one else's map in your ecu and you shouldn't use someone elses geometry either... Quote Link to comment Share on other sites More sharing options...
wilko Posted May 30, 2007 Author Share Posted May 30, 2007 it has been set up as near stock as possible just wondered if stock settings were for all wheel sizes Quote Link to comment Share on other sites More sharing options...
Mike B Posted May 30, 2007 Share Posted May 30, 2007 nope, not in the slightest! Quote Link to comment Share on other sites More sharing options...
