tdi hybrids
dwayne
thanks to everyone.
i just wanted to know the limits before i start playing with the boost controller.
i take it that it would not be a good idea to run at 21psi all day long then.
i have hks fuel rail 1000cc hks injectors and the fconv piggyback if that helps
cheers guys
cheers guys
sounds like your car was set up for something serious... had you thought of an AFR to see what it's doing - or take it to a rolling road? or did you set the system up yourself?
My second car came from japan with an Fconv mapped for the limit of Jspec fuel and it was a det monster on uk fuel, a total timebomb. I had to have it taken off and replaced with an emanage immediately.
Just offering some preventative advice; as unless you set the fconup yourself who knows what it's up to!
i didnt do it tdi did. its the fconv pro are they any different?
i do plan on taking it on a rolling road for a session soon, i havent a clue what the bhp figure is.
the bloke i bought it off spent £15,000 on the engine (i have the receipts) but i dont think he knew much about it and neither do i.
all help and advise is very much appreciated!
thanks
The pro is fine - and if TDI set it up you will be fine... I was just worried you might have got it straight off the boat (like my old one). The old Fcons are not possible to map in the UK (old models)
Some of the Vpro's have afr feedback/knock amps and these are self mapping too.
1000cc for hybrids is a bit severe though.. he mast have had big plans for the car! At least you'll be able to put a hairy single on in the future. :D
i'm sure mine has knock amps but not sure what they do. i read somewhere the evc5 shows the afr but i dont know how to bring it up on screen.
i am definately thinking of going single in the future, do you know if my fuelling is good enough for around 600rwhp?
sorry to put a bit of a downer on this.... But did you know the person you bought the car from?
I would get the car to garage (reputable) and get them to give the car a once over... an engine build for £15000?!?!!? Is a lot...Especially 1000c injectors and then hybrids?? My car has 680cc injectors and I think that is a tad on the overkill side for what I am running (fuure proofing :) ). What company was the build done at?
What else has been done to the car??
it seems strange to me now i have learnt a bit more about the car. just about everything has been done to the engine apart from internal work. he started with hks exhaust,filter and boost controller. then the 2nd turbo blew so the hybrids went on with the rest of the gear(typr r fmic etc)i will try to take photos of the receipts for a spec list and add them later.
i would love to know the reasoning for the overkilled mods because it makes no sense to me either.
maybe he did plan a big single but ran short of cash, i did get it for a very good price!
tdi did the work. its 6 speed
It could be genuine, and he just got the parts he did because they were cheap... it does sound odd!
the knock amp also reads AFR's if it's connected to a wideband O2 sensor.. it looks like the evc5 but displays the AFR reading (or not). If you don't have any way of measuring the AFR's then I'd say you could do a lot worse than getting an AFR guage for yourself.
EVC is only for setting the boost.. be careful with the stock system when using it on cold days.. unless you have a restrictor ring in the boost settings are not constant.. you can get quite a bit of creep (uncontrolled boost climbs) from the stock wastegate.
It sounds a little weird is, thats all. However he might have gone with the idea that I had... Get all the extras done first and leave the turbo for last. He might have just wanted a bigger single than I do... I basically ran out of mone before I got the single done, so decided to go hybrids for now.
Never dealt with tdi... can anyone comment on them?
TDI use to be a trader on here many moons ago.
They can be expensive but there cars seem to hold together well, my mate uses them for all his work on a supercharged IS200 and never has a bad word to say about them.
15g is not an awful lot of money on a 2jz gte, the F-Con pro is a serious piece of kit,
F-Cons can be mapped in this country...any fuel controller can be mapped in this country, and even if locked, they are self learning, so you shouldnt have had knock for too long
It would be good to see a spec list, I suspect from the 15K...it would include management, exhaust e.t.c which you have generalised as 'engine'?
My old HKS one couldn't and it wasn't self learning either.. HKS dealers in the UK wouldn't touch it.. think it was the Fcon-S.
o.k i have found the receipts but you will have to bear with me as i am unsure about what some of the abbreviations mean.
hybrid turbochargers
a/f equipment
front pipe
hks super dragger
evc5
fcd
sld type1
hks superfire plugs s40i
fcon v pro
wide band pressure sensor
vpc temp sensor
harness air temp
hks fuel rail
fuel reg evo
1000cc injectors
hks type r intercooler
plus various belts,hoses,lubricants,fluids, seals and labour charges
Guest Vsarin
Hi
A member of my family has a supercharged lexus and is active member of Lexusownersclub.
He used tdi for hks fcon vpro and someother mods to his car. was not very successful conversion in the end, car never ran right, even after taking it back 3 or 4 times to be rectified.
I dont know if you mate was the 1 sending him emails saying tdi's work was ok, (im sure he had black supercharged is200 if i remember) but it turned out that, the guy with the superchaged is200 sending emails, was a mate of the owner of tdi and gets all his work done at discount rates.
Needless to say, that when i find the right supra, and/if it needs any work doing then, i shall be looking elsewhere.
