Paul372 Posted May 30, 2007 Share Posted May 30, 2007 what can i use to patch up a rubber hose on my supe it got a little spilt init Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted May 30, 2007 Share Posted May 30, 2007 what hose? Quote Link to comment Share on other sites More sharing options...
RICHARDA Posted May 30, 2007 Share Posted May 30, 2007 Tape it for a very temporary repair until you can get a replacement ASAP. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted May 30, 2007 Author Share Posted May 30, 2007 what hose? its the hose that goes to the intercooler to the left above the airfilter as if your standing in front of the car Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted May 30, 2007 Share Posted May 30, 2007 you wont make boost with a split in that, get a new one... its k to temporary patch it up, wth gaffer tape tho, something strong Quote Link to comment Share on other sites More sharing options...
Paul372 Posted May 30, 2007 Author Share Posted May 30, 2007 you wont make boost with a split in that, get a new one... its k to temporary patch it up, wth gaffer tape tho, something strong thats all i wanna do is just patch it up temporary till i get a new one Quote Link to comment Share on other sites More sharing options...
Paul372 Posted May 30, 2007 Author Share Posted May 30, 2007 is it normal for a bit of coolant leaking from there Quote Link to comment Share on other sites More sharing options...
TLicense Posted May 30, 2007 Share Posted May 30, 2007 nope Quote Link to comment Share on other sites More sharing options...
Paul372 Posted May 30, 2007 Author Share Posted May 30, 2007 nope what can be up with my sup then, i replace the rad with a new one from mr ts and it doesnt feel like am losing any power but there is a little leak somewhere but cant find where it is coming from i through it was that hose cos the underneath of it had coollant on it? Quote Link to comment Share on other sites More sharing options...
Paul372 Posted May 30, 2007 Author Share Posted May 30, 2007 also this http://www.mkivsupra.net/vbb/showthread.php?t=112821 Quote Link to comment Share on other sites More sharing options...
Paul372 Posted May 30, 2007 Author Share Posted May 30, 2007 i ve taken that hose off cleaned it up and it is ok there is no spilt init so the coolant is geting flicked onto the underneath of that hose, so i must have a leak some where cos am losing coolant from the expansion tank where else can i look and would be losing coolant from Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 30, 2007 Share Posted May 30, 2007 Water pump? Just a possibility. Get a coolant system pressure test done. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted June 1, 2007 Author Share Posted June 1, 2007 Water pump? Just a possibility. Get a coolant system pressure test done. ok mate will have to get a coolant system pressure test done to rule that out will any garage do it Quote Link to comment Share on other sites More sharing options...
