going single questions?
j80leo
You have a FMIC that you can use....so thats 1g that you can take off of the ten you should be prepared to spend;)
Fuel
Management
Turbo
Not sure what size of exhaust you have but most likely it will be 3inch, so you could use that, if its not you should invest in a 3inch system at least
You will find it hard to achieve 600bhp on just a GT60 alone(RR dependant) Your auto box maybe a restriction for that figure,
Better cooling too will be needed the list is endless!
In response to your question...you wouldnt need to change pistons/internals for moderate boost but almost everything else!;)
Fuel
Management
Turbo
thanks fella i have got
greddy ecu
3" exhaust
hks fmic
hks boost controller
greddy plugs
hks filter
walbro 255 pump
just got to get the kit and hks injectors and as for the auto box i am stripping it out and putting a 6 speed in
I've had both those turbos.
You can't make 600bhp with a GT60. Not on pump fuel and sane boost levels anyway.
I doubt you could do it with a 4088 either but you'd get nearer.
Why the 600hp requirement anyway? Have you been in a GT60 or 4088 powered Supra?
not not yet jake:)
greddy ecu
3" exhaust
hks fmic
greddy plugs
hks filter
walbro 255 pump
Have a chat with Nic, he got me a HKS 680cc Fuel System, including all required parts for a decent price.
Private pile made 647fwbhp on marlins dyno with a .81 gt4088;)
As said the GT4088 will get you close to 600hp, the smaller T60 will make around 500+hp.
You'll need to budget around £10K for the build minimum to do it properly (ie. so that it is reliable). Ideally with that sort of power you should at least get your engine rebuilt with stock internals to make sure it is up to the job, ideally stronger internals.
You'll need to consider the following:
Fueling
Pump, injectors, rail, fuel ines, fuel pressure regulator, etc.
ECU + Mapping
What do you have at the moment, emanage or emanage ultimate?
Drivetrain
You'll need to fit a stronger clutch to cope with the power.
Do you have an LSD fitted?
Turbotkit
Quite a number of different setups to choose from. For around 600hp you're looking at T67, GT4088, PHR stage 2, HKS T-04, Greddy T78 etc.
Gauges
You'll ned a few gauges to monitor things eg. AFR, boost, EGT, OIl temp etc.
Cooling
Stock rad should be up to the job if in good condition, what HKS FMIC do you have fitted, the S or R type?
Oil Cool.
There are also a lot of other parts you will need, eg. plugs, gaskets, oil lines, water lines (if DBB), etc.
Fueling
ECU + Mapping
Drivetrain
Turbotkit
Gauges
Cooling
Oil Cool.
Fueling
got the Pump, and need the following injectors, rail, fuel ines, fuel pressure regulator, etc.
ECU + Mapping
emanage
Drivetrain
got an auto box in at the moment ang going to get a 6 speed
Turbotkit
Gauges
boost guage and getting air and fuel guage
Cooling
new stock rad type s fmic
Fueling
ECU + Mapping
emanage
Drivetrain
Turbotkit
Gauges
Cooling
The emanage is a bit limited, minimum you'd want at the power level you are looking at is an Emanage Ultimate, but ideally a standalone ECU.
The 2 row HKS S-Type FMIC is also not really up to the job at this power level.
