painting spark plug cover - advice
Fargo
guys,
the guys that have had there spark plug cover, what paint did you use, im concerned that if i use something incorrect the paint may start to crack.
also what did you use to finish/seal it for that gloss/shiny look.
Did mine at the weekend, sort of a spur of the moment thing. Gave it a quick scotchbright over then a couple of coats with the Rattle Can :cool:
Trouble is it's made the rest of the engine look shite :(
I brought a second hand cover that was painted already and I used nitromorse to get the old paint off and that worked well, then as above I used Halfords primer, paint and clear coat, it was easy and came up ok ;)
Where can you get that nitromorse from? Ive got an old one in the shed that i want to strip all the old paint off.
B&Q should have the stuff Gaz ;) Small green Tin if i remember correctly
Cheers
Ian
{EDIT} feck way to slow there !! LOL
