mathew Posted May 29, 2007 Share Posted May 29, 2007 this may be a no brainer but how tight should wheel nuts be? iv tightened them as much as possible by hand but do they need more? do i need to jump on the spanner (or whatever its called)? Link to comment Share on other sites More sharing options...
couv3z Posted May 29, 2007 Share Posted May 29, 2007 it would be best, to use the spanner and have them rock tight Link to comment Share on other sites More sharing options...
Al Massey Posted May 29, 2007 Share Posted May 29, 2007 if you had a torque wrench use that but if you dont hand tight would be fine,just dont go jumping on ya "spanner" may cause the bolt to shear Link to comment Share on other sites More sharing options...
edge Posted May 29, 2007 Share Posted May 29, 2007 Trail and error realy. If your wheels fall off then you didnt do them tight enough But seriously if in doubt do them up realy tight if you need to drive the car. I use an extension bar thingy. If You dont have a torque wrench get someone who knows to check yours just to make sure. Link to comment Share on other sites More sharing options...
Jive Posted May 29, 2007 Share Posted May 29, 2007 hand tight would be fine you serious? I'd be absolutely crapping myself if I knew my wheel nuts were only hand tightened! Link to comment Share on other sites More sharing options...
Al Massey Posted May 29, 2007 Share Posted May 29, 2007 most peoples hand tight is at least 70nm anyway and anymore than that on wheel nuts is reaching stress point Link to comment Share on other sites More sharing options...
merckx Posted May 29, 2007 Share Posted May 29, 2007 iv tightened them as much as possible by hand but do they need more? They should be okay, don't use an extension bar! Link to comment Share on other sites More sharing options...
Jive Posted May 29, 2007 Share Posted May 29, 2007 most peoples hand tight is at least 70nm anyway and anymore than that on wheel nuts is reaching stress point What about those that are really weak Link to comment Share on other sites More sharing options...
Al Massey Posted May 29, 2007 Share Posted May 29, 2007 What about those that are really weak then id be worried Link to comment Share on other sites More sharing options...
merckx Posted May 29, 2007 Share Posted May 29, 2007 most peoples hand tight is at least 70nm anyway and anymore than that on wheel nuts is reaching stress point You've made a mistake with your units, should be ft lbs Link to comment Share on other sites More sharing options...
Al Massey Posted May 29, 2007 Share Posted May 29, 2007 You've made a mistake with your units, should be ft lbs nope,i use nm,its what im used to working on tanks,everything is nm it would only be about 50 ft lbs anyway Link to comment Share on other sites More sharing options...
mathew Posted May 29, 2007 Author Share Posted May 29, 2007 thanks for the replies gentlemen:) Link to comment Share on other sites More sharing options...
merckx Posted May 29, 2007 Share Posted May 29, 2007 nope,i use nm,its what im used to working on tanks,everything is nm it would only be about 50 ft lbs anyway The recommended value is a little higher. 76 ft lbs or 103 Nm Link to comment Share on other sites More sharing options...
mattanna Posted May 29, 2007 Share Posted May 29, 2007 If you have an extendable wrench you should tighten nuts when car is on the ground with the wrench closed, overtighteneng is worse as they could shear or fracture, theu are boltys made to fit in the threads so should not come undone unles you have only tightened them with your fingers, closed wrench as tight as you can, and always in opposites of course:) Link to comment Share on other sites More sharing options...
Guigsy Posted May 29, 2007 Share Posted May 29, 2007 dont do the whole standing on it thing... if you want to know why check out my right rear bolts... all 4 of them Link to comment Share on other sites More sharing options...
