MONKEYmark Posted May 14, 2002 Share Posted May 14, 2002 hi just fitted my HKS electronic EGT gauge wired it all up and put probe into enginebay i have taped it next to the turbo`s on the metal sheet close to turbos to get a reading.i know i wont leave it there.its all wired up and does the self test thing.in manual it shows you the manifold but do you have to drill a hole in it there looks like a sensor in the front downpipe next to turbos but chris willson said this is a cat overheat sensor.is it possible to use that? i will be buying a front decat pipe from chris willson just wonderd if i could fit the probe myself.i am not very good with cars but i have fitted my boost gauge and egt gauge and intercooler hard pipe upgrade so far. just need some confidence to try othe mods. will go check it works by leaving car on idle till it warms up i know its not going to be a true reading but want to make sure it works ok thanks for any help mark Link to comment Share on other sites More sharing options...
Guest Martin F Posted May 14, 2002 Share Posted May 14, 2002 You need to drill and tap the exhaust maniold. Not a job for those un-familiar with taps & dies, because if you duck it up it could be expensive. Speak to Chris Wilson, he did mine for me. I don't actually know if you will get much of a reading taped to the outside of the heatshield as i think the first reading on the gauge is about 200 degC. I reckon your tape will smell nice at that temp Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 14, 2002 Share Posted May 14, 2002 You need to drill and tap the exhaust manifold BEFORE the turbos, after them will give inaccurate and useless, laggy readings. You need to know the temps as near to the ports as possible. This involves some dismantling, and modded drill bits and tap extensions. I can do the sensor install for 50 quid while you wait. I have made some special tools to do the job without extensive dismantling and have it down to a fine art now. Link to comment Share on other sites More sharing options...
Guest Martin F Posted May 14, 2002 Share Posted May 14, 2002 Jessszzzzz i should have waited a few months, Chris has a sale on!!!! ROFL Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 14, 2002 Share Posted May 14, 2002 Originally posted by Martin F Jessszzzzz i should have waited a few months, Chris has a sale on!!!! ROFL LOL. Times are hard, I have also made some tooling to help the job along Link to comment Share on other sites More sharing options...
MONKEYmark Posted May 15, 2002 Author Share Posted May 15, 2002 Originally posted by Martin F You need to drill and tap the exhaust maniold. Not a job for those un-familiar with taps & dies, because if you duck it up it could be expensive. Speak to Chris Wilson, he did mine for me. I don't actually know if you will get much of a reading taped to the outside of the heatshield as i think the first reading on the gauge is about 200 degC. I reckon your tape will smell nice at that temp hi martin i just put it there to test it.i have wired it up ok to say i have not done much work on my supra before.so i am chuffed i got it going with out much trouble.i have to sort out a frontpipe off chris wilson so i could go and pick it up and get probe fitted at same time.if you read this chris do you have any front pipes instock asap. i have the hks electronic gauge and think first reading is 300 or 500 cant quite remember. i will try ring chris tommorow. thanks for help some things are best left to the experts ps think i will fit my own t66 kit cant be that hard Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 15, 2002 Share Posted May 15, 2002 Originally posted by MONKEYmark hi martin i just put it there to test it.i have wired it up ok to say i have not done much work on my supra before.so i am chuffed i got it going with out much trouble.i have to sort out a frontpipe off chris wilson so i could go and pick it up and get probe fitted at same time.if you read this chris do you have any front pipes instock asap. i have the hks electronic gauge and think first reading is 300 or 500 cant quite remember. i will try ring chris tommorow. thanks for help some things are best left to the experts ps think i will fit my own t66 kit cant be that hard I have both UK and Jap spec front pipes in stock. Give me a ring on 01948-841581 before coming though, I only have 1 J-Spec front pipe, so if it goes I need to make some more. I can fit you in at a weekend if that helps? Link to comment Share on other sites More sharing options...
Markie Posted March 1, 2012 Share Posted March 1, 2012 This service still offered Chris? I am fed up of mind just blinking red at me because its not connected! Link to comment Share on other sites More sharing options...
Swampy442 Posted March 1, 2012 Share Posted March 1, 2012 9 years?? Best resurrection ever! Link to comment Share on other sites More sharing options...
Markie Posted March 2, 2012 Share Posted March 2, 2012 Asking if Chris still does this. Does it matter how old the thread is? Link to comment Share on other sites More sharing options...
monsween Posted March 2, 2012 Share Posted March 2, 2012 Asking if Chris still does this. Does it matter how old the thread is? He wasn't having a dig, just an observation dude Link to comment Share on other sites More sharing options...
merckx Posted March 2, 2012 Share Posted March 2, 2012 This service still offered Chris? I am fed up of mind just blinking red at me because its not connected! He's not guaranteed to see this thread, contact details are at the bottom of his posts. Regards, Chris Wilson. Race and performance road car servicing and preparation in north Shropshire. Race and road car engine building and tuning. Suspension development and geometry specialist, all Supra work and other cars too! Latest Bosch KTS and Vagcom diagnostics for all cars. 07971-952084 [email protected] NO PM's PLEASE! Link to comment Share on other sites More sharing options...
Markie Posted March 6, 2012 Share Posted March 6, 2012 Nice one.. Thank you. Link to comment Share on other sites More sharing options...
