Uprated Cam's.
Barry
Ok, what options do I have on fitting new (uprated) cams.?
I know its not quite the same, but when I fitted the Piper 285 to my 5 turbo it made a huge difference in power and torque and generally how the car behaved.  I know that cam's work very well on 'forced induction' engines and just want to know what options are out there for the Supra TT (j-spec).?
A rough idea on prices too if possible.! :)
Thanks.
B.
I have been looking into this a bit recently and this is what I have I have gathered for the UK/US spec car .
256 cams = tune for midrange torque,
264 cams = tune for small top end gain/bottom end loss on stock         turbo's  but really suited to bigger turbos.
272 cams = for really big turbo's.
If you want more perfomance and don't want too pay a lot of money you could do a lot worse than to pick up a set of used UK spec cams.
(Edited by GavinL at 5:56 pm on Mar. 26, 2002)
Quote: from Ring Master on 8:02 am on Mar. 27, 2002[br]Cams made a really nice difference to my supra (256in 264ex),
obviously Syed has tried them in his and wasnt impressed...
justin is the difference you noted on stock turbos???  or you hks turbos
i want a cambelt change and thinking of doing same size cams as you have on yours 256in 264 ex at the same time, also the cam gears too.
looking for hks brand
what sort of power can you expect with hks 256in 264 ex and cam gears.
do you need just a normal cam belt,think i read you need a differnt cambelt
i have stock turbos,blitz exhaust,induction,de cat pipe,dump valve.
i dont want to lose the kick down at the bottom end if at all possible.
ps justin did you get the email i sent about strut braces and some prices of parts
thanks
MONKEYmark,
My car does feel a little laggy at the bottom end, but I don't know if I can attribute it soley to the cams. Full spec of my car is:
6 Spd Silver J-Spec (RZ), Blitz ECU, Hybrid Turbos, HKS 'R' spec FMIC, ERL Water injection, Half decatted (was overboosting), HKS EVC (1.25bar), HKS Induction kit, HKS 'Priest' Exhaust, HKS cams 256in, 264ex, TDI uprated fuel pump, Uprated Clutch, Racelogic Traction Control, Front and Rear Strut Braces, Tein Coilover Adjustable Suspension, 18" Blitz Technospeed Z1 wheels, BM short shift kit, Greddy Boost Gauge.
My car doesn't fly away from the line, but give it a second and it takes off like a freakin' rocket and keeps going :). Doesn't bother me at all, but I can see how some people would prefer instant acceleration.
Graham
Graham Rudd
you got a lot of mods on there :)
i was curious about cams on stock turbos,i am new to tuning so learning as i go. whats the hybrids like against stock turbos for lag.also whats the advantage of the blitz ecu my mate has one on his r33 skyline gtr.is it just plug and play type
for the £1,300+ is it a straight out the box and install or is it a exchange for your old ecu
i tend to keep all the parts i take off in case anything goes wrong.
also what can you take to boost up to on the hybrids,do you have to get bigger injectors
trying to find whats a good way to go next
i know i could do with fmic and boost controller
thanks for any info
ps are the hybrids worth the cash or better off getting a t66
thanks for any info
thread hijack.....Monkeymark, please post these new questions in there own thread(s), you will probably get a better resonse that way
cheers
JUN AUTO CAMS!!! :)
You will want to have a longer duration on the exhaust than the inlet as the exhaust port is more restrictive so it needs to be open for longer.
256i 264e would be a good starter level - the lift of these cams is also important.
Jun Cams are all 9.3mm lift 256/264/272 duration, and they do a 272 with 10.8mm of lift (but that requires modified piston heads)
HKS run staggered lifts
248 degree duration, 8.5mm LIFT
256 degree duration, 8.95mm LIFT
264 degree duration, 9.25mm LIFT
272 degree duration, 9.35mm LIFT
Then there is Crower which has not been tried by anyone in the UK but seem to have a good reputation http://www.crower.com
Lag would not be increase UNLESS the fueling wasn't up to the task in that part of the rev range.
Hope this helps
GavinL  sorry about that
its the cams i was wanting to know about
would it be a good choice then going for hks 256in and 264 ex and hks cam gears
what kind of power could you expect on stock turbos and stock injectors
i might as well get them done as the cambelt could do with changing
thanks for the info
prefer to stick with hks
just want to find out what my options are before i spend the money
(Edited by MONKEYmark at 2:12 am on Mar. 28, 2002)
I don't think the exhaust port is such an issue with stock turbos. There is a school of thought that says the stock turbo's are the real restriction at this level, not the exhaust port and until you get into larger turbo's don't bother with anything over a 256 cam. The advice I have received for my car is inlet and exhaust HKS 256 with cam gears with a view towards extracting more torque in the mid range.
Unfortunately there seems to be very little hard data around to back up any opinion.
FWIW, I had HKS 272 degree cams on my Celica GT-Four,
and highly recommend them.  It made a huge difference,
especially in the top range, and allowed the rev range to
be extended too.
You'll need some way to retune the fuel delivery system.
I'll definitely be interested in Supra cams in the future.
Paul
Quote: from paulrenn on 11:19 am on Mar. 28, 2002[br]FWIW, I had HKS 272 degree cams on my Celica GT-Four,
be extended too.
Paul
Can't be all sunshine in the garden, what was the downside?
Quote: from MONKEYmark on 5:47 am on Mar. 29, 2002[br]i think i will go for hks 256 in 264 ex and hks cam gears
need to find a price and some tuner off here to fit
chris w   with the skyline and rx7 seems to know is stuff
where is he based
thanks for advice
I am in Shropshire, between Whitchurch and Shrewsbury, postcode SY132BT. I can supply and fit with pleasure. Or just fit or supply only, whatever. Suggest you have a new cam belt at the same time. E-mail me for phone numbers if you want to chat.
[email protected]
It's best to e-mail me direct, I am mad busy, start of the race season and all that, and can't find the time to pop into this forum as much as I would like. Cheers.
