DannoSupra Posted May 28, 2007 Share Posted May 28, 2007 I'll be taking the cyl head off the supra soon to change stem seals... What Head Gasket and Timing Belt should i go for? Also i'll be going sinlge soon, is it best to put cam's in it? or leave it till a later date? If so, which ones to go for? and is it a good idea to Port an Polish the head? Cheers Guys Dan Quote Link to comment Share on other sites More sharing options...
Jspec Germany Posted May 28, 2007 Share Posted May 28, 2007 subscribed Quote Link to comment Share on other sites More sharing options...
Kev.O Posted May 28, 2007 Share Posted May 28, 2007 Won't it be easier to go single at the same time. Seems crazy to put the stocks back on Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted May 28, 2007 Author Share Posted May 28, 2007 not botherd, Not as much cash as that atm, Plus Blue Smoke gets on my nerves!!!! Quote Link to comment Share on other sites More sharing options...
Jake Posted May 28, 2007 Share Posted May 28, 2007 Won't it be easier to go single at the same time. Seems crazy to put the stocks back on Can't you delay doing the stem seals until you go single? Taking the stokers off is a PITA anyway, putting them back on only to remove again later is madness! Anyway, stock Toyota head gasket and cam belt are great quality. I'd definitely stick with those. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted May 28, 2007 Author Share Posted May 28, 2007 so what cam's should i get? Quote Link to comment Share on other sites More sharing options...
michael Posted May 28, 2007 Share Posted May 28, 2007 so what cam's should i get? The ones best suited to the turbo you are fitting, standard might be fine. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted May 28, 2007 Author Share Posted May 28, 2007 thinks i'll be gettin a GT4088r or a T04z Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2007 Share Posted May 28, 2007 thinks i'll be gettin a GT4088r or a T04z If you want to a choose a suitable cam, then you need to choose your turbo and engine spec beforehand. The two you listed hardly have the same characteristics. Quote Link to comment Share on other sites More sharing options...
michael Posted May 28, 2007 Share Posted May 28, 2007 thinks i'll be gettin a GT4088r or a T04z The trendy choice As Homer says cam choice depends on a number of factors, I'm not changing the head on mine until I've identified the weaknesses of the standard stuff with the rest of the build. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted May 28, 2007 Author Share Posted May 28, 2007 ok then.../.. whts the GT4088 like? what sort of power will i get? when does it spool and peak Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2007 Share Posted May 28, 2007 ok then.../.. whts the GT4088 like? what sort of power will i get? when does it spool and peak Well, that depends on the spec of the rest of the engine, ECU and drivetrain. See where this is going now? You need to decide what YOUR goals are in terms of torque delivery, your driving sytle, what you use the car for, etc THEN build the engine (and rest of the car) around those requirements. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted May 28, 2007 Author Share Posted May 28, 2007 Righty, appreciate the help btw I'll be converting it to 6spd, using AEM ECU, Want around the 600-700 mark,. i dnt want it to be a Pig to drive, comfortable power, noting too laggy, i know there will be lag, but i dont want a power band of 1000rpm before having to change gear Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 28, 2007 Share Posted May 28, 2007 probably a stupid question but i'll ask anyway........... do the turbos have to be removed to remove the cylinder head? if you had a mate to help could the whole head not be lifted off with them still attached (obviously after disconnecting various water/oil pipes etc)........ Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2007 Share Posted May 28, 2007 Righty, appreciate the help btw I'll be converting it to 6spd, using AEM ECU, Want around the 600-700 mark,. i dnt want it to be a Pig to drive, comfortable power, noting too laggy, i know there will be lag, but i dont want a power band of 1000rpm before having to change gear There's some conflicting goals there Danno First off, do you know just how much power 600-700hp is on a road car? That sort of power level is simply ferocious and pretty useless on the road. If I were you I'd get a drive in a 'real' 550bhp car and see if you think you need more Secondly (and before we discuss further) what is you budget for the entire conversion, and how much can you spare per month to keep it running? I'm not trying to be a kill-joy, but these massive bhp figures are thown around here by some people like they're nothing. Planning a conversion around your needs is essential... disregard peak hp goals at this stage. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted May 28, 2007 Author Share Posted May 28, 2007 hmm i kno... maybe 500ish should be more my liking... see im glad i ask the experts... Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2007 Share Posted May 28, 2007 probably a stupid question but i'll ask anyway........... do the turbos have to be removed to remove the cylinder head? if you had a mate to help could the whole head not be lifted off with them still attached (obviously after disconnecting various water/oil pipes etc)........ I think it could be done if you have a proper ramp, but would be very tricky (oil lines, water lines and turbo supports are a nightmare to get to with the turbo's in place). It would probably be easier taking the turbo's off at the manifold - and I don't say that lightly Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted May 29, 2007 Share Posted May 29, 2007 The ones best suited to the turbo you are fitting, standard might be fine. and in 99% of cases this is true...a mild overlap is often all thats needed for a turbocharged engine, if in doubt speak with an experienced cam grinder Degree the OEM cams once the single is on Quote Link to comment Share on other sites More sharing options...
Nic Posted May 29, 2007 Share Posted May 29, 2007 For information Toyota sell a complete gasket/oil seal kit for the head. Kit includes everything you'll need, head gasket, cam seals, etc. 04112-46056 Valve grind gasket kit Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 29, 2007 Share Posted May 29, 2007 I think it could be done if you have a proper ramp, but would be very tricky (oil lines, water lines and turbo supports are a nightmare to get to with the turbo's in place). It would probably be easier taking the turbo's off at the manifold - and I don't say that lightly ah i forgot about the support brackets to the block......... Quote Link to comment Share on other sites More sharing options...
